Hi,
This is my first post on this form. I'm trying to get back into SDRs again but SDRTrunk is kicking my butt.
I need some help building the JMBE.jar file. I'm following these instructions DSheirer/jmbe but every time I run the build command I get this:
BUILD FAILED in 44s
5 actionable tasks: 3 executed, 2 up-to-date
I Will post the whole command prompt at the bottom.
When I first started trying to build it it would error out on what verson of java I had. But i got past that with some trial and error just to hit another wall.
So I need some help am I just making some noob mistake, do I still have the wrong java, or something else?
Thanks for any help
BUILD FAILED in 44s
Thanks for any help
Code:
Microsoft Windows [Version 10.0.17763.437]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>echo %JAVA_HOME%
C:\java8
C:\WINDOWS\system32>javac -version
javac 1.8.0_40
C:\WINDOWS\system32>cd C:\Users\zeame\Downloads\jmbe-0.3.3b\jmbe-0.3.3b\
C:\Users\zeame\Downloads\jmbe-0.3.3b\jmbe-0.3.3b>gradlew.bat build
Starting a Gradle Daemon (subsequent builds will be faster)
> Configure project :
Your finished JMBE library is here: C:\Users\zeame\Downloads\jmbe-0.3.3b\jmbe-0.3.3b\build/libs
FAILURE: Build failed with an exception.
* What went wrong:
Could not resolve all files for configuration ':jmbe:compileClasspath'.
> Could not resolve org.slf4j:slf4j-api:1.7.25.
Required by:
project :jmbe
> Could not get resource 'https://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.7.25/slf4j-api-1.7.25.pom'.
> Could not GET 'https://repo.maven.apache.org/maven2/org/slf4j/slf4j-api/1.7.25/slf4j-api-1.7.25.pom'.
> java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
> Could not resolve com.github.wendykierp:JTransforms:3.1.
Required by:
project :jmbe
> Could not get resource 'https://repo.maven.apache.org/maven2/com/github/wendykierp/JTransforms/3.1/JTransforms-3.1.pom'.
> Could not GET 'https://repo.maven.apache.org/maven2/com/github/wendykierp/JTransforms/3.1/JTransforms-3.1.pom'.
> Could not resolve pl.edu.icm:JLargeArrays:1.6.
Required by:
project :jmbe
> Could not get resource 'https://repo.maven.apache.org/maven2/pl/edu/icm/JLargeArrays/1.6/JLargeArrays-1.6.pom'.
> Could not GET 'https://repo.maven.apache.org/maven2/pl/edu/icm/JLargeArrays/1.6/JLargeArrays-1.6.pom'.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
* Get more help at https://help.gradle.org
BUILD FAILED in 44s
