Kenwood TK-2312 Key Programing
davebells
Hi- I used to have the TK-2170 and I was able to program the buttons on the radio to go to a direct channel. I now have the TK-2312 but when i go to key I can not figure out how to program the buttons to go to a direct channel.
IE. when i hit the B button I want it to go to a set channel that is programs and so on with all the other buttons.
I do have the Kenwood KPG-101D Programming Software, and the Kenwood KPG-22 USB programming cable. I am looking for help just setting up the Key Assignments to go to a certain channel.
Any one have an idea how to get this done.
ramal121
Lots and lots of watts
Calif Whine Country
You have already asked the same question in another thread. You should continue in that thread and not start a new one.
You cannot use KPG-101D for a TK-2312, KPG-134D is required.
To answer your question, you would program a button as "Direct Zone/Channel". To use you would select the channel on the radio you'd like to be the "jump to" channel. Then press the Direct Zone/Channel button for three seconds. Now a quick press of that button will bring you back to the channel you just set no matter where you are in the line up.
