I have a BCD436HP and a Larsen Tri-band antenna. I have a vehicle mount for the antenna but was looking to see if there is a way to direct mount the antenna to the scanner also? Wouldn't be used often but would like to have the option for times I'm away from the home antenna and outside the vehicle for extended period without all the extra cable from a spare mount that I have been using for this situation. I can't seem to locate a SMA or BNC direct to the NMO mount the antenna uses. The tri-band picks up significantly more of what I want to hear than the stock antenna when tested side by side.
