Lathrop PD
russianspd
Maybe it's just me but I haven't heard any Lathrop units on SO. I know they opened their new PD and am wondering are they working on their own channel now or are they still with the SO?
Radiobern
San Leandro
russianspd
https://www.ci.lathrop.ca.us/police/page/dispatch-services indicates they are being dispatched by Ripon PD.
I also searched the FCC database and found the following license: http://wireless2.fcc.gov/UlsApp/UlsSearch/license.jsp?licKey=3956150&__newWindow=false. They are licensed for 453.225, 453.3125, 453.475, and 453.775 and has emissions for P25 and FM.
I would start with those frequencies and see if anything is heard.
Much appreciated. Will dial that in and see. Living on the west upper side of the County I doubt I'll get anything. RPD and EPD barely come in on my car unit when mobile.
russianspd
So far 453.2250 with a NAC of 701 seems to be their dispatch channel. Their units are 3B(boy)XX Lathrop.
russianspd
Should I add this to the DB?
I would say so, yes. I listened for over a day and it was all Lathrop PD based on traffic and addresses. This morning apparently County Dispatch was acting up and 453.3125 with a NAC 701 which is listed as TAC 32 covering Lathrop/Manteca was being used for dispatches. It's listed already but seeing as how it's also listed in the freqs RadioBern posted, I think it can be added into the Lathrop group itself. I think they are still being Dispatched by County. Still have to figure out these two: 453.475, and 453.775
officer_415
SF Bay Area
I added the new Lathrop PD frequency (453.225 MHz). I'll hold off on changing Tac 32 (453.3125 MHz) until we know a little more, but I assume fire doesn't use it since the rest of their channels are VHF?
russianspd
As of about 10 ago they are still using 453.3125 to dispatch locally and they had a call in Ripon and had them change to Command 6 for that. Obviously not enough to make a solid decision about how they will use that channel. Will keep listening.
officer_415
SF Bay Area
So Ripon Fire District now uses Command 6, not 5?
Flicknnn
Stockton ,Ca
Hi guys ,I have enter the public frequency for Lathrop ,listed in data base , I'm not getting no audio .
Perhaps I'm To far away ?
russianspd
You're also in Stockton, right? I find that in order to even barely receive LPD, you need to be in an "optimal" radio spot where even the troublesome channels come in nicely. For me it's either outside in my backyard or upstairs next to the window or if I am downstairs in a very specific spot that I spent quite a bit of time trying to balance being able to catch all of my troublesome frequencies where they come in nicely. I'm located northwest side of Stockton south of Hammer. Hope this helps.
officer_415
SF Bay Area
Nevermind, I checked the Broadcastify archives and confirmed that Ripon Fire uses Command 6. DB updated
russianspd
Sorry about the late reply. I did check and see your previous post awhile back but didn't respond at that time. Yes, I've done some more thinking and anything north of SR4 seems to be command 3 and everything south including Lathrop are either on command 6 or SCD south dispatch. The part that is still confusing to me is the uncertainty of which units will be dispatched from which channel. You have control 1 which is supposed to be their main dispatch channel but then you also have units that get dispatched directly from SCD south. Some radio traffic will be solely on command 6 or on SCD south. It's sort of a mess but works for them I guess. I still have not heard anything on command 5 and can't remember it ever really being used, perhaps it can be removed unless someone else can confirm it still being used in some capacity.
officer_415
SF Bay Area
As explained in the other thread, it's two different dispatch centers. SCD is just the South County Fire Authority (City of Tracy, and Tracy Rural Fire Protection District). They're dispatched and respond on SCD.
The other agencies are dispatched on Control 1 and respond on their geographically appropriate channel (Control 3 or 6).
russianspd
Thank you much for the final clarification. Makes much more sense now. So SCD is just for Tracy and Tracy area and then everyone else such as Escalon, Ripon, and Manteca fall onto command 6 but still dispatched through control 1?
