LCD Display Flicker
bob550
Albany County, NY
My new G5 (VHF), received four days ago, is experiencing a screen-related issue, and I don't know if this is normal behavior. When the brightness level is adjusted to 50% or greater, I will notice a slight flicker of increased brightness toward the center of the screen. At first, it seemed random, but I eventually realized it occurred whenever there was activity on the display. Any activity such as a change in signal strength, or even the call duration timer, causes this flickering. My question is whether this is normal behavior, a firmware glitch, or a hardware problem. I've attached two screenshots showing a normal screen, and one with the flicker. (The vertical lighter area to the right of the screen in both images is room lighting/reflection.)
bob550
Albany County, NY
So, I'd guess that no one else has seen this LCD flickering occur with their G4/5?
IAmSixNine
Dallas, TX
Either no one has seen it or not everyone monitors this forum on sundays / the weekend.
Ive never seen it.
bob550
Albany County, NY
I have had my G4 for a year and a half and have not noticed any type of flickering, nor have I heard of it in any of the forums. I would contact your dealer.
I emailed my dealer earlier today, and he's looking into this for me. The flicker is slight but noticeable, especially at higher brightness levels. It's not that the entire display flickers, but it's closer to a momentary increase in brightness in the darker areas of the screen.
