LCN
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Those channel numbers look more like a Hytera system then Cap Max....Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
There are a couple of threads in the Canadian Atlantic Maritime forum (where I'll suggest this be moved) that suggests that this system is not labeled correctly. It looks like it should be a Tier 3 system, not Cap Max. As I understand it, Cap Max is Motorola's adaptation of the Tier 3 protocol but isn't quite the same thing.
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
While you're waiting, look here; this is where your area is covered. I would also ask that your title be changed - just saying 'LCN' isn't going to get a lot of attention. They will rightly ask 'LCN for WHAT?"
Mike
hfxChris
Dartmouth, Nova Scotia
Mike
Hmm? It's definitely a capacity max system...
sonm10
Central MN Monitor
Sauk Centre, Minnesota
Those are the channel numbers from dsd+
If an odd number, subtract 1, divide by 2
If an even number, subtract 2, divide by 2
This only applies to cap max and other TIII systems. Con+ and Cap+ use a different formula
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This belongs in the wiki - we're trying to gather all these little tips like this in one place
Mike
GTR8000
NY/NJ Database Guy
BEE00
Then shouldn't this be listed as a MOTOTRBO Capacity Max system, and not TIII? I can easily see the confusion, because I sure am....Mike
The system is correctly listed as DMR Tier 3 Capacity Max. Capacity Max is Motorola's implementation of Tier 3. While Capacity Max does have some proprietary MOTOTRBO features, it can also be run in full Tier 3 compliance mode if desired.
You sure about that? The three threads I just read through don't seem to suggest that at all, in fact it was confirmed that it is a Capacity Max system, and that's exactly how it's listed in the RRDB.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes quite sure....
(messages 26 and 27)
in which it's stated that this is a Motorola Cap Max system (OK fine...)
Mike
GTR8000
NY/NJ Database Guy
BEE00
Yes quite sure....
Mike
And the issue is? The system is listed correctly in the RRDB. Uniden scanners do not distinguish between Tier 3 and Capacity Max; it displays DT3 for both. Perhaps that's another request for Joe, to have it show DT3 for generic Tier 3 and MAX for Capacity Max, but as of right now, they are not distinguishable without using software like DSD+.
