Lcra p25
Sanscanman
N5WRF
Acworth, GA
SITE 132-32 AUDIT(DB TICKET SUBMITTED)
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 200
System Name : Lower Colorado River Authority (LCRA) P25
WACN : 92571
Tower Number (Decimal): 132-32
Tower Number (Hex) : T8420
Tower Description :
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) :
Timestamp : Fri Oct 30 06:25:13 2020
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.00625,0.01250,30.00000,"Confirmed",0.01250,1
01,851.00000,0.01250,-45.00000,"Confirmed",0.01250,1
08,769.00625,0.01250,30.00000,"Confirmed",0.01250,2
09,851.00000,0.01250,-45.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0322","c",773.03125,"00-0322",803.03125,0,0
"00-0345","avd",773.31875,"00-0345",803.31875,0,5
"00-0382","avd",773.78125,"00-0382",803.78125,0,6
"00-0405","avd",774.06875,"00-0405",804.06875,0,2
"00-0442","avd",774.53125,"00-0442",804.53125,0,4
"08-0690","v",773.31875/0,"08-0690",803.31875/0,0,1
"08-0764","v",773.78125/0,"08-0764",803.78125/0,0,2
"08-0810","v",774.06875/0,"08-0810",804.06875/0,0,1
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
10303,"T6703",200,"00-0053",769.66875,"New Braunfels"
10606,"T6A06",200,"00-0135",770.69375,"Gonzales"
10707,"T6B07",200,"00-0387",773.84375,"Kingsbury"
13131,"T831F",200,"00-0052",769.65625,"Cibolo"
FrankieD210
Cibolo, Texas
Is this TG Phase II or encrypted? My scanner (396XT) keep stopping but no audio. Listening on the new Cibolo Tower.
80401f68DNBVFD Common 2New Berlin VFD Common 2 (patch with 154.4900 MHz) Fire Dispatch
NC5267
San Antonio
Monitoring right now. Phase I unencrypted and most of the units have P25 ID's. It is still patched with the VHF. You can hear the radio ID tone after each transmission on the guys that are still using the VHF side.
rattlerbb01
TX/LA Database Admin
Boerne, Texas
I was listening to both about an hour ago passing through seguin. Agreed.
Sanscanman
N5WRF
Acworth, GA
80401f68DNBVFD Common 2New Berlin VFD Common 2 (patch with 154.4900 MHz)Fire Dispatch
There is some sort of data poll taking place on that TG. It starts up about 5am and happens about every 15 minutes. Procomm shows it as just a data call that keeps the tg active for upto 30 seconds. If you listen very carefully you can hear a data pattern in the carrier. I see it more on Cibolo site, but it does appear on seguin’s site as well. Also just noticed that Tg is listed as Fire Dispatch. Should be Fire tac.
FrankieD210
Cibolo, Texas
Yes, I turned up the volume and could then hear it. I guess I'll keep in locked out for now since it holds up the scan with no useful transmission. Thanks for clearing it up for me.
Sanscanman
N5WRF
Acworth, GA
John,
What you are seeing is the freqs that Procomm noted with slot info for the phase two talk-groups. I think when the info was imported they just forgot to remove them.
Sanscanman
N5WRF
Acworth, GA
System ID : 200
WACN : 92571
Tower Number (Decimal): 102-2
Tower Number (Hex) : T6602
Tower Description : Creedmoor
Flavor : Phase 2
Call Sign(s) :
Timestamp : Tue Nov 3 07:28:49 2020
-Tables
-Frequencies
"00-0017","a",769.21875,"00-0017",799.21875,0,0
"00-0054","a",769.68125,"00-0054",799.68125,0,0
"00-0324","c",773.05625,"00-0324",803.05625,0,0
"00-0347","a",773.34375,"00-0347",803.34375,0,0
"00-0384","a",773.80625,"00-0384",803.80625,0,0
"00-0407","a",774.09375,"00-0407",804.09375,1,0
"00-0444","a",774.55625,"00-0444",804.55625,1,0
-Neighbors
10101,"T6501",200,"00-0035",769.44375,"Austin"
10404,"T6804",200,"00-0426",774.33125,"San Marcos"
10707,"T6B07",200,"00-0154",770.93125,"Kingsbury"
11313,"T710D",200,"00-0037",769.46875,"Bastrop"
11414,"T720E",200,"00-0344",773.30625,"Johnson City"
12727,"T7F1B",200,"00-0052",769.65625,"Dripping Springs"
Sanscanman
N5WRF
Acworth, GA
FileVersion:8
-TowerInfo
System ID : 200
WACN : 92571
Tower Number (Decimal): 114-14
Tower Number (Hex) : T720E
Tower Description : Johnson City
Flavor : Phase 2
Call Sign(s) :
Timestamp : Tue Nov 3 08:02:11 2020
-Tables
-Frequencies
"00-0344","c",773.30625,"00-0344",803.30625,0,0
"00-0367","a",773.59375,"00-0367",803.59375,0,0
"00-0404","a",774.05625,"00-0404",804.05625,0,0
"00-0427","a",774.34375,"00-0427",804.34375,0,0
"00-0464","a",774.80625,"00-0464",804.80625,0,0
-Neighbors
10202,"T6602",200,"00-0324",773.05625,"Creedmoor"
11515,"T730F",200,"00-0364",773.55625,"Spicewood"
12121,"T7915",200,"00-0017",769.21875,"Luckenbach"
12323,"T7B17",200,"00-0346",773.33125,"Smithson Valley"
12626,"T7E1A",200,"00-0134",770.68125,"Wimberley"
Sanscanman
N5WRF
Acworth, GA
TGID 8032 Guadalupe County Fire Disp. Just heard New Berlin dispatched on this TG
Not sure if this is Linked to the Hickory Forest repeater or this is covering the whole county. I have seen TGID 8031 come up a few times as well but no activity on it.
NC5267
San Antonio
12121(which is not in the DB) today seems to be some training exercise for Cibolo PD. Seems like routine radio traffic but a mobile unit is dispatching calls like Schertz dispatch does. Seems to be a lot of stolen vehicles and a man with a gun calls for Cibolo. Why I think it's a training channel.
jbsarandolphmonitor
Air band monitoring JBSA-Randolph
Schertz, TX
I have tg 12121 listed as Cibolo PD Training. I was waiting to hear more on the tg before I submitted it to the db.
Don
mostlychris
Did something change with the Bergheim site? I can no longer hear anything from it..or the control channel has changed to one not listed.
mostlychris
I am hearing it now. Not sure what happened. It almost acts like I didn't have the frequency used as the CC.
KG1ADP
Moto
Texas
Make sure you have all the control channels in your scanner. Harris systems change control simultaneousley not like the motorola system where it keeps the same control channel.
