Quite funny you say that as I never stated I was planning on hooking this up. Seems you have misplaced the term "newbie" with "assumptions."
There is nothing wrong with being a "newbie". We were all newbies at one time.
In your original post you stated that you already applied power and asked how you check the power output. In another post you asked if a DVM could be used to check the output. Together, it is an indication that you are not going to use it as a paper weight and plan to hook it up. So you are a "newbie".
As others may have stated, to test the output power you need a power supply that is capable of outputting 12 Volts at 60 Amps, an RF source between 1-5 Watts, a power meter, and a dummy load that can handle the full output power.
The design of the amplifier is based on the classic broadband designs that were published by Motorola in Application Notes in their RF Devices Data Book from the 80's. Those designs were really meant only as a starting point for more elaborate designs. The App Notes listed below are a good example. They are lower power designs, but it gets the idea across. They are good reads and will help you understand what the designs are based on.
www.k7mem.com/manuals/AN-779.pdf
www.k7mem.com/manuals/AN-593.pdf
But many manufacturers took these initial designs and started making amplifiers. And, why not. The application notes provided everything they needed to know, including the PDB design. Usually they eliminated pesky things like effective bias for linear SSB operation and output filtering. The output filtering is to eliminate the fifth harmonic products. There is often a switch that selects AM/SSB, but that does nothing to the bias. All it does is add some extra time to the transmit sensing switch, so you don't go out of transmit every time you pause for a few seconds.
You will even see these designs in older Amateur Radio Handbooks. However, they do stress bias and output filtering.
Are these amps used? Yes, by CBers and by licensed amateur operators, who should know better. I have seen bios on QRZ.com where they brag about using these amps, with no modifications.
But they can be made legal, at least for use by a license amateur operator. Amateur radio operators are allowed to built their own transmitters, receivers, and amplifiers. So if you treat the illegal amp as a part and then add bias for AB2 operation, add an output filter, and eliminate that automatic transmit sensing, the amp is legal to use on the amateur bands. Adding proper bias will probably reduce the efficiency of the amp and lower the output power, but that shouldn't be an issue.
I have a amp that is labeled as a Pride-150. But the same design goes by several different names. I bought it at a ham fest for $15. However, I modified mine so that it is legal to use on 10 Meters with my HTX-100.
