LMRN General Discussion
EJB
20 + year membership
Downtown Hamilton
For the 1st time in months I'm now getting the MTO Patrol Talkgroups on both my SDS100 and 436.
I haven't even been trying and busy with other stuff but I guess since the Charlton LMRN control channel went to 142.35 I'm hearing MTO Patrols clear enough.
Weird.
mrweather
I haven't even been trying and busy with other stuff but I guess since the Charlton LMRN/PSRN control channel went to 142.35 I'm hearing MTO Patrols clear enough.
Weird.
I've had LMRN on my SDS200 (Mississauga, King City and Toronto towers) for several months but I've heard nothing. What am I doing wrong?
gpsdepot
I am here
Maybe update the database in the scanner, as changes are happening regularly.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
On the Toronto 5Foxtrot talkgroup it was announced that Whitby and Pontypool towers will be unavailable for the next two hours.
mbstone99
Hamilton, Ontario
Weird.
Same here with Charlton.. I took out the bandplan I had attempted to use and gave it a try and was able to hear the MTO Patrols.
Matt
gpsdepot
I am here
Just heard that on SIM 11 as well
Dispatcher telling all units on Toronto talkgroup to switch over to " LMRN " now
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Normally, I will pull in what I consider ten local towers on FleetNet. Today, that rotation flies by quickly. It is down to three: Ballinifad, Primrose and King City, the rest zoom by.
Still active: Caledon, Dufferin, Nottawasaga, Southern Georgian Bay, Orillia/Severn OPP and 17360 ,also some encrypted Investigative talkgroups are seeing some action.
Primrose seems to be a hot tower for the remaining OPP in the clear if you monitor from Toronto.
An odd one just popped up, talkgroup 39600. Calling out to OPP from test console: This is Corrections Unit Charlie 1-7-Gulf "How do you read?" This appears to be ongoing as the are calling out different Units on 39600. Of course, you don't hear the OPP response.
mrweather
Okay thanks. I updated the database in June but will try again.
It's just that I'm not receiving *anything* even though it's clearly picking the towers.
gpsdepot
I am here
Changes are almost daily, a lot has happened since June
slicerwizard
Toronto, Ontario
I see Oxford often patched with Perth 19040. On FleetNet, Oxford was often patched with Norfolk. If it is Norfolk, it will be TG 19036. If you restart DSD it should show the patched TG when it first decodes the site.
Or just click on either of the last two entries in the Control menu...
gary123
Expect the primary CC to be moving around for a while, or at least until the remaining users transition. Once that is done, there may be a little finetuning on which CC on what site gives the best coverage without causing issues.
Saint
Fort Erie Ontario Canada
I have made a YouTube video about the transition from: Bell FleetNet Ontario Provincial Government to: Public Safety Radio Network (PSRN)
Where would be the best place to post it? Any ideas?
Saint
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Since it is of local interest, make a new thread in the Ontario forum and attach the video there.
mrweather
Yep, the most recent database update is Sept 1, so got it loaded now. I started seeing OPP popping up but since they're encrypted, the radio keeps on scanning.
EJB
Downtown Hamilton
I dunno if the question has been asked:
If encryption is so cheap and busy to install, why aren't the MTO Patrol talkgroups encrypted as well? For the tows? If not for them why don't they encrypt everything?
