LMRN Technical Data Discussion
mbstone99
Hamilton, Ontario
This was on the Hamilton site but I am not sure what TG 20708 is used for other then being a MOH TG but just saw the 'Emergency" tag show up for a good 15-30 seconds of transmissions on one of the RID's on this TG.
Just saw it again and these two RID's 753342 & 752439 both had the Emergency tag.
Matt
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Interesting. I captured 20709 yesterday afternoon, likely on Fonthill. I've been monitoring Fonthill site a lot now since I can now receive it from Toronto.
P25, BEE00.AD9, 20709, 754325, 50, Normal, 2, 2024/11/21 15:31, ""
VA3ADP
Mississauga, Ontario Canada
Just captured 23125 with RID 752225 off of Mississauga/Britannia DSDPlus with FastLane shows "AH-MIS-BCH". Safe to say this is the hospital for Brampton Civic Hospital with the corresponding ER Radio.
I also have 23121 to 23128 logged. I imagine this range is for the Mississauga CACC hospital patches for Trillium Health, William Osler, and Halton Healthcare. I am actually surprised with the amount of patches between a busy ER like Credit Valley, I haven't found more aliases.
thecanadiangod
Ottawa
I found this out yesterday. All LMRN zones also have 4 new talkgroups called "Sector 1, 2, 3, 4". They are encrypted though.
gary123
Did you get the TG values? if you have DSD maybe the RID and KIDs used on the TGs if they are active. The more we log the more we know. :)
thecanadiangod
Ottawa
A radio joined a bunch of TG's on the Ottawa site today for what I assume is training, they joined these different talkgroups. 20941, 20942, 20943, 20961, 20960 , 20604, 20606.
no transmissions on any of them, just joins. the RID that joined was 755614
mciupa
Canadian DB Admin
Moderator
I'm here a lot
In the western area these are the talkgroups that saw activity throughout 2024
P25, BEE00.AD9, 20600, 50, Normal, 2, 2024/06/10 8:55, " (TDMA)"
P25, BEE00.AD9, 20602, 50, Normal, 1, 2024/09/12 11:53, ""
P25, BEE00.AD9, 20603, 50, Normal, 0, 2024/02/08 12:23, ""
P25, BEE00.AD9, 20605, 50, Normal, 5, 2024/11/22 16:46, ""
P25, BEE00.AD9, 20606, 50, Normal, 0, 2024/06/19 14:40, ""
P25, BEE00.AD9, 20607, 50, Normal, 27, 2024/04/25 17:59, ""
P25, BEE00.AD9, 20608, 50, Normal, 9, 2024/07/10 16:15, ""
with these radios
(TDMA)
P25, BEE00.AD9, 20600, 773728, 50, Normal, 2, 2024/06/10 8:55, ""
P25, BEE00.AD9, 20603, 750220, 50, Normal, 0, 2024/02/08 12:23, ""
P25, BEE00.AD9, 20605, 750382, 50, Normal, 0, 2024/07/30 13:23, ""
P25, BEE00.AD9, 20606, 750359, 50, Normal, 1, 2024/05/27 13:52, ""
P25, BEE00.AD9, 20607, 750992, 50, Normal, 13, 2024/04/10 12:27, ""
P25, BEE00.AD9, 20607, 751968, 50, Normal, 0, 2024/04/25 17:59, ""
P25, BEE00.AD9, 20608, 754536, 50, Normal, 3, 2024/07/10 16:15, ""
the 209's after Oshawa CACC are unknown at this time.
thecanadiangod
Ottawa
Got more activity on the Ottawa site today, with two Tx's on TG 24440 by UID 15006. These were both encrypted
755826, 755551, 755827 are doing many Tx's right now on 20940. Pretty sure these are dispatch UID's
VA3ADP
From what ive seen, the dispatch consoles for MOH start with 773xxx and OPP 730xxx
exkalibur
York, Ontario
Assuming the entire system follows the same pattern, those are likely ambulance bases. It would make sense to have all the infrastructure setup before the system goes live.
tayridge
Silent Key
ELGIN ONTARIO CANADA / tayridge34@gmail.com
MORTON TOWER INFORMATION
Network: BEE00.AD9
Bandplan #0: Base=136.005 Offset=-4.02 Spacing=7.5 BW=12.5
Bandplan #1: Base=136.005 Offset=-4.02 Spacing=7.5 BW=12.5 Slots=2
Bandplan #2: Base=136.005 Offset=-4.05 Spacing=7.5 BW=12.5
Bandplan #3: Base=136.005 Offset=-4.05 Spacing=7.5 BW=12.5 Slots=2
Bandplan #4: Base=136.005 Offset=-2.235 Spacing=7.5 BW=12.5
Bandplan #5: Base=136.005 Offset=-2.235 Spacing=7.5 BW=12.5 Slots=2
Bandplan #6: Base=136.005 Offset=-2.145 Spacing=7.5 BW=12.5
Bandplan #7: Base=136.005 Offset=-2.145 Spacing=7.5 BW=12.5 Slots=2
Bandplan #12: Base=769. Offset=+30 Spacing=6.25 BW=12.5
Bandplan #13: Base=769. Offset=+30 Spacing=6.25 BW=12.5 Slots=2
Bandplan #14: Base=851.0625 Offset=-45 Spacing=6.25 BW=12.5
Bandplan #15: Base=851.0625 Offset=-45 Spacing=6.25 BW=12.5 Slots=2
Site: 1.57
Channel 0-884: 142.635 CC
Site: 1.62
Channel 0-866: 142.5 CC
Site: 1.67 NAC=AD7
Neighbor: BEE00.AD9-1.57
Neighbor: BEE00.AD9-1.62
Neighbor: BEE00.AD9-1.80
Neighbor: BEE00.AD9-1.81
Neighbor: BEE00.AD9-1.83
Neighbor: BEE00.AD9-1.90
Neighbor: BEE00.AD9-1.91
Channel 0-848: 142.365 CC
Channel 0-854: 142.41 SCC
Site: 1.80
Channel 0-812: 142.095 CC
Site: 1.81 NAC=AD1
Neighbor: BEE00.AD9-1.67
Channel 0-818: 142.14 CC
Channel 0-920: 142.905 SCC
Site: 1.83
Channel 0-880: 142.605 CC
Site: 1.90
Channel 0-828: 142.215 CC
Site: 1.91
Channel 4-756: 141.675 CC
kybervon
Trenton, ON
Question for folks; I’m using an HP-2 to monitor the Demorestville site. When viewing Current Activity it shows the following:
LCN Fx. TGID UNIT ID MOD
1 856.4812 SYS:0AD9h SITE:1-086
Any input as to why it’s displaying that 800mhz fx?
Thanks in advance.
//dt
w3rwn
Perhaps you are really close to the Demorestville tower and picking up a harmonic/multiple of the VHF transmitter.
The HomePatrol scanner has a wide front-end, (like all scanners). With a strong VHF signal, the multiplication effect can happen in the scanner itself as well.
856.4812 / 6= 142.746
142.740 is a VHF frequency normally associated with that tower.
