XPR Looking for XPR7550e VHF CodePlug AAH56JDN9RA1AN
Seiiki
Just looking to pre-setup a codeplug before the xpr7550e radio I ordered Model AAH56JDN9RA1AN. I believe it was programmed with CPS 2.0, any way to swap it to CPS 16 as I read that 2.0 doesn't support bluetooth anymore. Thanks in advance!
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
The codeplug is specific to the radio. You can't just grab a random codeplug that matches your model number, build it out, and dump it into your radio. You will need to read your radio once it arrives, then build your codeplug, then write it to the radio.
If the radio was last programmed with CPS2.0, you are out of luck using CPS16.
