Los Angeles Regional Interoperable Communications System (LA-RICS) - Master Thread
osxscan
Just heard some LASD testing this morning on Rio and Johnstone. All in the clear from what I heard.
bcorbin
Los Angeles
That must have been what I heard on Oat this morning. Caught the last couple of seconds of the last transmission 8*(
By any chance did you note the TGID or RID?
bcorbin
Los Angeles
Sorry I did not catch that info
No worries... I actually did discover a couple of hits on a backup receiver I had running, and it looks like they were on TG 1. Thanks for the post - I probably wouldn't have gone looking if you hadn't confirmed what I thought I heard 8*)
LAflyer
Global DB Admin
Moderator
SoCal
I see in LA-RICS board meeting agenda that LASD will be issued 262 portables as part of early deployment testing and usage by specialty units.
Document states the early deployment system would serve as proof of concept including giving LASD encryption capability.
Some of the units to be issued the radios include: LA IMPACT, Aero Bureau, Arson/Explosives, Crisis negotiation teams, multiple detective divisions and also the Avalon patrol station.
I suppose in the coming months we will be hearing various new talkgroups appear on the system.
osxscan
Does it seem like it's going to be officers choice for "E" or permanent?
LAflyer
Global DB Admin
Moderator
SoCal
I'd suspect it could be like ICIS where some talkgroups are simply set up as E from the git go.
LAflyer
Global DB Admin
Moderator
SoCal
This afternoon hearing LASD SCC Access (483.5625) patched on TG 3.
Receive both dispatcher and units with none of the LASD standard beeping.
RadioSquad
Banned
Does anybody know if more towers are going to be out up near the Orange County LA County borders?
patin
carson,california
receving on pro 651
i thought this was phase 2 p25 and not able to monitor on pro651 models ,,im receving just fine accually have a new talk group TRANSIT SERVICES LASD (talk group 4) receving well off the 700 p25 freq
patin
carson,california
INDY72
Indianapolis, IN
It is an P25 Phase 2 capable system. It can use P25 Phase 2 TDMA as well as P25 Phase 1 FDMA TG's.
LAflyer
Global DB Admin
Moderator
SoCal
Yes TG 4 is LASD Transit Service Bureau dispatch with both sides of comms without the historic beeps.
Wonder if this is a semi-permanent set up for the early deployment testing by LASD, or something the radio techs have set up as a one-off configuration for a few days?
Markb
Planet Earth
PSEC used the lower-numbered TG's for testing only. IIRC, the new San Berdoo sysrem is shaping up the same way.
Also, I believe that the P25 standard calls for phase 1 backwards compatibilty on a phase 2 system.
bcorbin
Los Angeles
For what it's worth, none of this is popping up on Oat... meaning the folks who are monitoring these TG's aren't wandering around much. I suspect this is all testing...
bcorbin
Los Angeles
....I take that back...
It looks like these TG's are all tdma (and I had an old radio parked on Oat). TDMA sounds good coming through Verdugo, Oat sounds like crud.
