Lost freqs!
quadro
I have a Pro-197 and have somehow lost some of the programmed freqs,any advise on what to do. Thanks
RBMTS
Did you look at the manual for the radio?
tvengr
Well Known Member
Baltimore County, MD
On a Pro-197 you don't have banks. You have scan lists. Pressing buttons 1 thru 0 on the keypad toggle scan lists 1 thru 10 on and off. Pressing the function button and then 1 thru 0 toggle scan lists 11 thru 20 on and off.
CT
Wholeo1955
Northeast, CT
Ok ive owned 8 pro-197's ive not ever had the issue im now going through im getting with my now only 197 left it shall work in my car for 1-3 days then it craps all out this is the message I know am getting! For LIKE the 10th time and where my scanners mounted this is a very tough place to get those bracket screws out as well too so van you provide to me why this is happening to only this scanner, and no other scanners, ive had nor sold prior to?????
Wholeo1955
Northeast, CT
Wholeo1955
Northeast, CT
HERE IS THE TROUBLE AND WHY I AM BACK FOR MORE HELP, MY RADIO SHACK SCANNER MODEL PRO-197 AND THIS IS MY FULL, STORY, THE MEMORY KEEP DISAPPEARING FROM IT AFTER 1-8 DAYS OF SITTING STILL, NOT GOING FROM ITS SPOT AT EVER AT ALL!,,,,,HERE'S MY QUESTION????? DOES THIS MODEL HAVE BACK-UP BATTERY IF SO WHERE IS CENTER CIRCUIT BOARD?? FRONT CIRCUIT BOARD ? OR NONE!
Ok ive owned 8 pro-197's ive not ever had the issue im now going through im getting with my now only 197 left now! Please Help me OUT to solve this issue, as soon as we can please! Thanks so much for looking to try and find me, THIS helping hand please!!
Chronic
I have reprogrammed this scanner 8 times, to get the very same result, ALL LOST DATA !!!
is it actually losing the memory , or just forgetting that scan lists are enabled . Try just re-enabling the scan list from the keypad. Also you could add your programing to virtual scanner to make re-loading easy from just the keypad .
