Madison County, KY new radio system thread
trashman43
Kentucky DB Admin...
Kentucky
Tower 1001
FileVersion:5
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 001
System Name :
WACN : 92065
Tower Number (Decimal): 1001
Tower Number (Hex) : T0A01
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Thu Feb 18 14:04:30 2010
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
00,851.01250,0.01250,-45.00000,"Confirmed",0.00625
-Frequencies
#Format: Channel,Usage,Frequency,Input Frequency,Hit Count
"00-0051","v",851.65000,806.65000,3
"00-0091","v",852.15000,807.15000,3
"00-0111","v",852.40000,807.40000,3
"00-0231","v",853.90000,808.90000,4
"00-0438","c",856.48750,811.48750,0
"00-0518","v",857.48750,812.48750,4
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
2002,"T1402",001,"00-0114",852.43750,""
trashman43
Kentucky
Tower 2002
FileVersion:5
-TowerInfo
System ID : 001
System Name :
WACN : 92065
Tower Number (Decimal): 2002
Tower Number (Hex) : T1402
Control Capabilities : Composite control channel,Data,Voice,Registration
Call Sign(s) :
Timestamp : Thu Feb 18 13:27:35 2010
-Tables
-Frequencies
"00-0053","c",851.67500,806.67500,0
-Neighbors
1001,"T0A01",001,"00-0091",852.15000,""
trashman43
Kentucky
TG's 7 Rradio ID's
FileVersion:5
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
11,50,"T: 1001 DT: 2/18/10@13:11",1266519821,"02/18/2010 @ 14:03",1266516707,"02/18/2010 @ 13:11","#000000","#000000"
FileVersion:4
# Radio List for this system
# Format: RadioID(Decimal),Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),Text Color,BG Color
1000004,"TG: 11 DT: 2/18/10@13:14",1266519790,"02/18/2010 @ 14:03","#000000","#000000"
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
Here is a change to the New Madison TRS (WQLD409/411)...
change: 852.48750 to: 851.03750
these are the freqs per ULS:
851.65000
851.67500
852.15000
852.40000
852.43750
851.03750
853.50000
853.90000
856.48750
858.48750
856.73750
857.48750
857.73750
858.73750
859.48750
859.73750
860.48750
860.73750
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
I have a friend in Richmond, who was asking me today about this system. She plans on buying a new PSR-600 scanner to follow the emergency responders across the county. With that said, I did a search and found that Madison County has another application pending before FCC. Apparently, they want to add five new frequencies to the system, three of which will be at the Big Hill site.
Letter of Concurrence
Letter 1 from Sprint
Letter 2 from Sprint
FCC Pending Application
Harris Electronics, always uses a System ID of 001, when a P25IP TRS is in testing mode. Usually, they will switch it to a valid ID once the system goes live. When that happens, start looking for users to make the migration from the old to the new radio system.
Yours truly,
Ron
unitcharlie
Gathered some additional TGIDs this morning, will rearrange the current Talk Groups into categories and modify those as this system stands-up.... Really crisp audio this morning!
hundley206
Scanning
Is anyone able to receive any Madison county activity on your scanners? I have a Uniden BC796D digital
scanner, I have programed the new freqs in as type 2/P25 800 but i can not receive the new date channel. Iv tried this with both the new and one TRS together and just the new TRS . I do get the old data channel but no activity when i add the old and the new i only get the old data channel. Does anyone have any hints for me? or is Madison county un scanable?
unitcharlie
I have the new TRS working in a PSR 500 and BCD396T... not familiar with the 796, but the specs say it should track the system.... you might try programming the freqs but leaving out all the freqs listed as CCs in the old TRS... see what that does for you.... let us know in the forum so we can kinda keep track of the scanners that will follow it.... there is one Madison County rr.commer who has his PRO 96 following the system (although I can't get mine to track it) so there is hope!
hundley206
No luck
Thanks for your help but no luck. I guess its time to start shopping for a new digital scanner. How do you like your PSR-500? witch seems to do better the PSR-500? or bcd-396t
unitcharlie
I prefer the PSR 500 because of the way I work.... easier to use with one hand.... Scanner Master has them for $398.00, Don Starr's software Win 500 is $35.00 (you need software to keep track of everything)... The new TRS tracks well with either scanner, I have received some transmissions well into Lexington...
pdunn92074
Richmond, Kentucky
Pro-95
Does anyone know if a PRO-95 scanner can follow the systems in Madison County here now. I was using it fine but have not had it on it a month and so and now I can't seem to bring in anything. Also what system are they using now and how is it different from before. I am thinking of getting a Uniden BCD-396xt if I cant get this one to work soon.
pdunn92074
Richmond, Kentucky
Anyone picking up anything on the new Madison County system with the new Uniden HomePatrol1 radio? I just got mine in today and will try and see what it can do tonight.
pdunn92074
Richmond, Kentucky
Yep it seems to be working fine. I am just trying to get my favorites list sorted out with the channels I want to monitor, but it is picking up everything just fine it seems.
