Manually Programming Baofeng UV-5R
W6SAE
Woodland, California
I recently came across this blog post: WP4AOH: Baofeng UV-5R Overview and Manual Programming
It demystifies the process of manually programming the UV-5R. It gives good information regarding radio settings and step-by-step instructions for programming for repeaters, stepping up or down frequencies, CTCSS, etc. After entering a few channels, I had the steps memorized.
I hope this might be of help to some of those who find programming this radio a challenge.
W6SAE
I'm not sure why this thread was moved, as the UV-5R is indeed targed toward amateur radio (among other services) and is widely used by licensed amateurs.
KE0GXN
Echo Mike Two-Seven
Because, most all Chicoms are considered "Budget and Entry Level Transceivers" would be my guess...
The "Amateur Equipment" forum here seems to be reserved for the "big three" and Alinco from what I have seen.
W6SAE
Someone should poll the membership to see how many UV-5R owners are using them as "amateur equipment." I suspect it would be the vast majority.
I'll let the the matter drop now, although I think the move has limited the number of people my post could potentially help by taking it away from the intended audience.
KE0GXN
Echo Mike Two-Seven
Maybe a Mod will chime in and explain.... I am sure they have their reasons. I just recently started participating in the amateur radio sections of this forum, so I don't know the history here.
73
W6SAE
73
I guess I don't either. I'm relatively new, as well.
N4GIX
Hot Springs, AR
I think that how "difficult" the process might be depends on where one bought their UV5R. The one I ordered through Amazon came with the typical "Chinglish mangled manual." The one I bought through the Texas distributor came with a very nicely printed, fifty-three page manual in proper English.
The latter manual was easy to read, and had very detailed steps for everything. Of course, having used Chirp and the programming cable, manual programming is a lot less attractive. It is good however to know how to do it manually so that if one needs a particular frequency while in the field, one can accomplish the task! :)
Thanks for taking the time and interest to post the link though, as I'm sure it will prove useful for others just getting started.
TheSpaceMann
It's a little annoying, but once you get the hang of it you can manually program them without a hitch.
W6SAE
