MDC Tool
FoxMcCloud
I'm new to MDC and Motorola. I have a few HT1250's and a GMRS license. There's a video on youtube describing the MDC Stun feature
. What program is this? Where can I get it? What will I need for it? Are there any easy and cheap alternatives? Sorry for asking all these questions but Google did not yield any results for me. Since I'm using my radios on GMRS I don't want some jerk to stun my radio while I'm working.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Stun (and Kill) are MDC features in dispatch consoles. They are rarely seen anywhere else.
If you don’t enable MDC on the receive side,
Stun and Kill are effectively disabled. There’s not much need for MDC in GMRS anyway.
I had MDC running for a while on my GMRS radios and since it’s me and the wife only, it got annoying fast.
Giddyuptd
Here and there
A downside with it is anyone can see your id, a maliciously send a kill command from a radio that is capable of sending commands.
While it don't happen much it can.
FoxMcCloud
Thanks, I have all motos on freq so it mutes the full ack. I agree the full ack will get annoying really fast. I deployed motos for our work and have MDC enabled for identification. I had two motos die last week, now that I know stun and kill only will work if MDC is enabled for receive. That was just due to a failure of the radio.
FoxMcCloud
As the other user was mentioning, will this only happen if MDC is enabled on received? Won't they also need the DPL tone my radios are set to?
Giddyuptd
Here and there
If your radio isn't set to accept checks or stun then you are fine.
If it is only allowing mdc on pl/dpl proper decoding then you are fine.
If it Wil accept mdc data on anything csq to pl/dpl and is enabled for stun or check then it'll respond to that.
gatekeep
FAIL 01/93
New York, NY
He's showing my MDCTool application; which I had released on Microsoft's CodePlex a long time ago. CodePlex has since shutdown, and obviously I think that repository/project there is gone. But you can find the code here: gatekeep/MDCTool
Its just a fancy UI stuck on-top of a port of Matthew Kaufman's MDC1200 C libraries (which you can find here: atmatthewat/mdc-encode-decode).
Be aware this software (other then the README I added today...) hasn't been touched in several years and I give no warranties or support for it.
FoxMcCloud
Thanks for posting that, I'll try it out in a VM
FoxMcCloud
How do I configure my radio to do that in CPS?
Giddyuptd
Here and there
Under mdc, there should be boxes to tick to enable radio check, radio stun in the mdc personality menu for each personality.
FoxMcCloud
I uncked radio checking here, but there does not seem to be an option in the conventional personalitiesMDCcontext.PNG
gatekeep
FAIL 01/93
New York, NY
The Waris line of radios always has the Radio Check, Stun and Revive commands enabled. I do not believe there is an option in the CPS to change those settings.
FoxMcCloud
There was a check box for radio check. I disabled that. I turned on only accept data on proper dpl tones. I used it today and had no problems
