MicroP25RX
dustinsterk
So many antenna choices......Remtronix 820 seems to be a go to.
  • Like
Reactions: btt
dcr_inc
Not an EXPERT !!
Delta, Pa
What would the file name be for talkgroups on system
45DDD (WACN) 037 (sys Id) ?
Talkgroups_45ddd037.csv?
KevinC
32D2T/957.282
I'm everywhere Focker!
Dug through my filters and found a bandpass from 700 up to around 860 or so. As far as cellular goes it will only block T-Mobile (600 MHz). My decode is still good so more evidence it was broadcast TV causing my issues.
KMG54
Easley S.C.
My dsd files imported today just fine not sure Todd's understand it but cut half the stuff out off there.Let me restate that, he knows but used my scan list and most are good, best thing is the lockouts are locked out.
  • Like
Reactions: btt
KMG54
Easley S.C.
Oh oh, mine was playing fine and the WIO went blank, have rebooted and tried every thing DOA now.
KMG54
Easley S.C.
First causality, was plying fine, Wio went blank now nothing.
KMG54
Easley S.C.
Going to reload all the firmware Wio has lights but no video.
maus92
Eastern Shore
Did you try disconnecting the Wio from the board and plugging it into power, then cycle the reset slider?
KMG54
Easley S.C.
Oh well I always wanted a SDS, looking like the wat to go. The micro was fine until all of a suden while listening display went blank and Scanning stopped. Tried everything, the Wio has lights, but no video, nothing is out of place on the p25micro.
KMG54
Easley S.C.
It is the Wio that took a dump. It will do nothing on the screen when plugged in. Will try to reload, wish me luck.
KMG54
Easley S.C.
reloaded the WIO hAVE VIDIO NOW, JUST HAVE TO GET AUDIO NOW,sorry about the caps, working on other things.
KMG54
Easley S.C.
Sorry about the typing, have no idea what happened to the Wio, but with a new flash all is well again.
goldmyne99
Once configured, the MicroP25RX will run with the info saved in it's flash without the Wio connected.
  • Like
Reactions: btt
btt
Jew lover
Wa State
Been away from the computer for a few hours now, so I still need to go back and read everything. This isn't the first time I've hear of the Wio going into bootloader mode and the firmware needing to be reloaded. I've never seen this happen myself. I don't know what causes it, but this is the 3rd time I know of it happening. The MicroP25RX is independent of the display, but with the current setup the Wio does control the frequency changes for scanning. I did it this way so that people who wanted to change the way scanning works could modify the open-source code for the Wio. You can find the code here: GitHub - tvelliott/MicroP25RX_Wio: Firmware source for the Wio-terminal portion of the MicroP25RX product
