MicroP25RX
robnj74
Buena, NJ
Not sure if this has been asked yet but would it be possible through a firmware update to be able to program the WIO through the micro usb on the Teensy board or through the WIO itself using it micro sd reader ?
  • Like
Reactions: btt
dustinsterk
@btt FYI, once you load the new firmware it takes about 45 seconds to show/confirm the firmware version number on the flash->show config page. That page just shows empty values until the elapsed time. Not an issue at all but just wanted you to be aware.
  • Like
Reactions: btt
btt
Jew lover
Banned
Wa State
It isn't possible with the current firmware.
Yes. I might speed that up. It doesn't send that information very often. This way it takes up very little i/o bandwidth .
robnj74
Buena, NJ
Ok it was worth asking. Oh as for sensitivity I'd say it does ok..
  • Like
Reactions: btt
btt
Jew lover
Banned
Wa State
There is another thread that was recently closed for further replies regarding the audio jack. Even though I did not reply to that thread, I have been in communication with Kevin regarding this issue. I offered to replace the audio jack for free and pay for the return shipping. This was before the thread was closed. I feel I need to say this here since the closed thread makes it appear that I was unwilling to fix the issue. That is not the case.
btt
Jew lover
Banned
Wa State
Does priority only work if park on a CC?
The answer is yes and no. The firmware was allowing TG PRI INT for a new voice grant, but was not allowing ant INT during an in-progress conversation if roaming was enabled (scanning). FW 1129-02 will allow TG PRI INT to work regardless of the roaming/scanning mode.
Soledad, CA
Yeah I was wondering if it was working at all nothing was happening . Also I notice sometimes some TG's zones that are disable make it through with a tone even though I have it disable. I guess that little tone is the priority tone.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I figured it out. The BTT didn’t have a problem. I apologize.
btt
Jew lover
Banned
Wa State
What was the issue in case some of us have the same problem in the future?
Let's just say, it is hard to tell what is actually going on with this. I've offered multiple times offline to fix it, pay for return shipping. Multiple times. I also said I prefer to be honest here on RR. I don't want to publish the private email thread, but this is bull****. Just so you all know. I don't know what to believe, but something is not right here.
KevinC
32D2T/957.282
Super Moderator
Nothing is going on. I realized I screwed up in my troubleshooting and I’m admitting it.
KevinC
32D2T/957.282
Super Moderator
Anyway, back on topic.
If you guys aren’t taking advantage of the TG/Zone feature you should really look into it. It’s a way to separate agencies so you only hear what you want when you want (especially if you imported from RR and have hundreds or thousands of TG’s).
W0RS
Nixa, MO
Oh heck, I was hoping it would not return 🤦🏼‍♂️ I am running 11.28.01 and I saw NAC changed again. So, your idea of adding a config option to lock the correct NAC value per site is want would be needed. It’s something to put on your to do list 🙃👍
KMG54
Easley S.C.
Todd is being quite again, must be working on some improvements. :p
