MicroP25RX
btt
Jew lover
Banned
Wa State
While on the topic of this, I think I found a hang-up. Either I hit the limit of ID's able to be imported, or it doesnt allow duplicate ID's. Each time it will import all of the ID's from one of my CSV's but then it gets partway through the second and freezes. The 2 systems have an ISSI link and radios frequently pop up on talkgroups on either system, so i just copied the entire list and gave it the corresponding names. For reference I have around 6000 Ids in each file.
If you want to email me the files, I will try importing here and see if I can reproduce. I don't think it should be an issue.
dustinsterk
Wanted to thank @btt for all his help in getting me up and running! NJ has some strange control channel issues here but as you can see it working like a charm in sync with my SDS100. What a great device so far (still have a lot to learn)!
btt
Jew lover
Banned
Wa State
Should be fixed now. 11-25-02 will import the alias files. Note that the 12000 aliases take up approximately 7% of the flash.
dustinsterk
cmjonesinc
Anyone have suggestions for a smaller antenna for a more portable solution: Would this work?
Yeah that'll work fine. I'm using one with no issues
maus92
OCMD
Yes it would work, but you will need to be careful going portable with that antenna attached as it could exert a significant moment on the connector / pcb if dropped or got caught on something.
maus92
OCMD
Interesting that the simulcast site is C4FM and not LSM.
dcr_inc
Not an EXPERT !!
Delta, Pa
Ok.. I give up.. I did something and now all it does is scan systems and sites and NEVER stops on any talkgroups.
Is there a way to set it for unknown talkgroups while scanning?
KMG54
Easley S.C.
ScannerDude were did you get the 90 degree SMA adapter?, Never mind I found them. Found them on Amazon, but were two weeks out dug deeper and will have them Wednesday.
dcr_inc
Not an EXPERT !!
Delta, Pa
Found it !! I had TG Zone 001 disabled.. Live and learn !!
  • Like
Reactions: btt
dcr_inc
Not an EXPERT !!
Delta, Pa
One more question.. How do I remove a (or multiple) systems from my scan list ? I have a few that I don't care to listen to, Ever
dustinsterk
I ended up doing a SD backup, editing the file on my computer/removing all the sites I did not care about, then doing an SD card restore. This also allows you to easily edit talkgroups and make bulk changes without the need for a bunch of key presses on the device.
I would love some more information on what each of these attributes actually do in the user manual (future improvement?).
