Mid-Atlantic MilAir 2024
mdmonitor
0916- Mace 91 (F-16C 169th FS, SC ANG McEntire ANGB SC) working ZDC Kenton (354.15)>ZDC Cape Charles (236.825>ZDC Flat Rock (235.625) at FL220.
0920- Burner 1 working ZDC Cape Charles (236.825)> Norfolk A/D (370.925).
0930- Unid acft (missed call) working ZDC Kenton (354.15)>ZDC Cape Charles (236.825).
mdmonitor
1005- Fund 31 (KC-46) working Brickyard CP (237.15) advising they are enroute to AR 636 for AR w/8 F-22s and request callsign check. Confirms calls are FLASH & ICEMAN. At 1010 Iceman flt working in W386 (238.1/255.65/312.2/315.85/350.05/358.85)
1015- Tora 81 (T-6) off DOV (132.425) heading west.
Lots of TEDDY callsigns and even some DEED calls, I'm sure I missed some today...
KECK239/TEDDY73 (AE117B) picking up motorcade then dropping helo in ILG
TEDDY77 (AE49C4) heads to Philly with VP equipment
TEDDY85 (AE0800) into BOS with motorcade
Also DEED175 (AE4F15) on the way back from ATL & DEED153 (AE0808) back from Detroit
KECK207 motorcade to/from MHT
frank3si
New Castle DE
0850- They're starting to leave DOV. Golden Knights acft GKA 609 off DOV (132.425) heading south.
I did make it back to Dover this morning for “the informal show” - departures from this weekend’s First State Airshow. I arrived at eight and things were quiet but after an hour an F-16 kicked things off. In the next two hours I saw four F-15s, an F-22, two T-6 Texan 2s, a U28-A Draco (I’d say there’s a good chance this will be the only time I see one of these in flight), two F-35s, a KC-135, and Doc the B-29. But the undisputed star of the show for me was the B-52, the only aircraft that used the runway directly in front of me to fly over my head in stunning fashion. This shot is 200mm with no cropping, indicative of how close the encounter was. I wish I could post the hi-res image, but I’m sure you get the idea…
Afar1505
Looks like a AF1 return today, 09-0018 is on the ground at ILG
Thank you -- this one does show up at 09-0018 on adsbx, but I believe it's actually 19-0018. 09-0018 doesn't seem to exist.
https://www.airfleets.net/ficheapp/plane-b757-28172.htm
Yes, you are correct, but since that is the way ADSBx lists it that is what I call it (as do many others) to make it easier for people to locate it for tracking.
Tuesday travel...
POTUS travels to NH and Boston, Mass
9:10 AM THE PRESIDENT departs the White House en route to Joint Base Andrews
9:40 AM THE PRESIDENT departs Joint Base Andrews en route to Merrimack, New Hampshire
10:55 AM THE PRESIDENT arrives in Manchester-Boston Regional Airport, Nashua, New Hampshire
3:05 PM THE PRESIDENT departs Manchester-Boston Regional Airport, Nashua, New Hampshire en route to Boston, Massachusetts
3:45 PM THE PRESIDENT arrives in Boston-Logan International Airport, Boston, Massachusetts
8:35 PM THE PRESIDENT departs Boston-Logan International Airport, Boston, Massachusetts, en route to Joint Base Andrew
9:55 PM THE PRESIDENT arrives at Joint Base Andrews
10:05 PM THE PRESIDENT departs Joint Base Andrews en route to the White House
The VP also heads out of town...
At 10:15 AM ET, the Vice President will depart Washington, DC en route to Philadelphia, PA.
At 11:00 AM ET, the Vice President will arrive in Philadelphia, PA.
At 3:00 PM ET, the Vice President will depart Philadelphia, PA en route to Washington, DC.
At 3:50 PM ET, the Vice President will arrive in Washington, DC.
Today 2 CT ANG C-130's, 92-1453 & 96-7322 (Yanke42) departed ACY. They are currently over Colorado. I wonder if the 177th is heading west.
Seems both aircraft into KMCY Monterey Regional airport.. Odd stop.
BLUES-75 seems like headed towards Travis.. Maybe A/C guys getting a Hawaii trip later?
