I changed the measurements. I found that placing the amplifier/balun box 70cm from top wall of box to top of loop gives 60cm between both sides of the loop. This provided better nulling effect ableit minor improvement.
What would happen if you used elements larger than specified? Would it resonate and cover lower frequencies? Or would it just overload?
Not sure. Some guy off this website reverse engineered it and said something inside is not the right impedance. Waiting for someone to speak up on using a bigger radial.
I also want to say that the MLA 30+ will have a higher noise floor but it pulls in way more signals than a telescoping whip can receive. This makes me think of the idiom that says, "When the tide is high, so are the ships."
