Mohave County info needed
rbuxton
Hesperus, CO
I am looking to confirm some gaps in my Mohave County freq listings.
Oatman Fire repeater? (AKA as Bullhead City FD Fire 14 - Oatman Fire Admin)
MCSO Channel 6 Kingman TAC ?
MCSO Channel 7 Oatman ?
MCSO Channel 8 Meadview ?
MCSO Channel 13 River ?
MCSO Channel 14 SAR Repeater ?
Also, does anyone know the usage of the following freqs? (found in FCC ULS):
158.745000
154.875000
154.755000
154.950000
158.760000
158.865000
460.250000
460.350000
Thanks.
rbuxton
Hesperus, CO
Come to think of it,,,, I think my listing for MCSO needs some updating. Here's what I have.
Ch 1 Dist. 1 Kingman156.150000 / 155.535 inCTCSS 173.8Hz
Ch 2 Dist. 2 Mohave Valley155.640000 / 154.815 inCTCSS 192.8Hz
Ch 3 Dist. 3 Lake Havasu155.040000 / 155.730 inCTCSS 186.2Hz
Ch 4 Dist. 4 Dolan155.655000 / 158.910 inCTCSS 136.5Hz
Ch 5 Dist. 5 Strip West155.910000 / 154.890 inCTCSS 110.9Hz
Ch 6 Kingman TAC155.580000CTCSS 173.8Hz
Ch 7 Dist. 2 Oatman??????
Ch 8 Dist. 4 Meadview??????
Ch 9 Dist. 4 Wikieup155.655000 / 158.910 inCTCSS 173.8Hz
Ch 10 Dist. 5 Strip East158.730000 / 155.190 inCTCSS 110.9Hz
Ch 11 Kingman Admin (Animal Control)155.880000 / 154.995 inDCS 165
Ch 12 SAR (Car to Car)155.160000CTCSS 173.8Hz
Ch 13 River??????
Ch 14 SAR Repeater (Jail?)155.670000 / 159.015 in
Ch 15 Dist. 4 Dolan Springs154.882500 / 159.360 inCTCSS 162.2Hz
AIRS4155.475000CTCSS 173.8Hz
avdrummerboy
Mohave County, AZ
Where did you get the list? Pretty complete and I've not seen one. Only MCSO frequencies I know for sure is Ch.1 through 3 as well as Ch.15.
Oatman FD (Ch. 14 in the radios) I have as 154.4300/ 151.0850 PL-173.8. I have multiple frequency guides saying that but I have never heard anything on it. When I was dispatching, it was always a spotty repeater and Oatman FD usually came across on Ch.11 for Mohave valley FD
rbuxton
Hesperus, CO
Thanks for the info. I was hoping you'd reply since u live here and I don't. I'm usually passing through with an overnight stay. I used to be here more often when my mom lived in Golden Valley. Anywho,,,,,,,,, the MCSO list came from its 2019 Strategic Plan (page 59).
https://resources.mohavecounty.us/file/Sheriff/Forms/MCSO-Strategic-Plan-2019-DIGITAL.pdf
https://forums.radioreference.com/attachments/mcsoradio-png.77414/
avdrummerboy
Mohave County, AZ
Can now also confirm that Ch.4 for Dolan Springs is correct as I used it for work out here a few days ago.
I am curious how you got 155.5800 as Kingman TAC as it is listed as dispatch/ ops on the site? Did you hear it used that way?
Also was curious how you got Ch.9's frequency pair since what you have as Ch.9 is different than what's in the DB but I have never heard anything on the frequencies listed in the DB and that repeater doesn't even key up in our work radios w/ that freq. pair.
Still trying to find anything about an Oatman or Meadview Repeater pair or perhaps a low level remote site in those areas.
rbuxton
Hesperus, CO
Reviewing the FCC database and using deductive guessing is how I came to list the frequency pairs as I have 'em. I have not heard 155.580 or the freq pair listed as Ch.9. Again, using the FCC database showing the transmitter/repeater sites and the map provided by MCSO is how I came to my list,,, which obviously needs some local confirmations.
avdrummerboy
Mohave County, AZ
I'll listen when I'm out in Kingman working. Put Ch.11 on in Bullhead City for an entire day and even with PL disables never heard anything at all. Only place I hear any activity on Ch.11 is in Kingman and it is definitely ACO (11A units) but is clearly Kingman area only. Not sure what other frequencies are used for ACO in the rest of the county so that's another unknown around here. I'll do some listening on the Kingman TAC and see if I can confirm anything about that as well as the Jail/ SAR Ch.14.
rbuxton
Hesperus, CO
SAR repeater on my list was a bad guess. That freq pair is definitely the jail. Ch. 11 is fer sure Animal Control but I would take an educated guess that it is not only used by animal control. Based on my map and the FCC database I figured it was Kingman Admin (with a change to the input freq - 154.950 - which I determined while passing thru earlier this week.
Thanks for putting in the effort to get this figured out.
BNSFscanner
From my notes for several visits into the Mohave County area I found the following:
Simplex, unit to unit, 154.950 near or in Kingman, largely encrypted. I found an old reference to this channel as "Command One" with no channel number. It was active for several hours recently.
Their Channel 7 is for the Oatman area dispatching 155.580 Repeater, with an input of 154.845. I think the tone was 118.8.
avdrummerboy
Mohave County, AZ
Interesting, that 154.950 is the input to Ch.15, which is at the very least ACO but possibly an admin channel overall. Never heard any reference to command 1 but I'll try and do some listening and see what comes up. I'll give that channel 7 pair a try and see what comes up, my guess is they don't have units up there all too often so it might be a dead channel most of the time. That also calls begs the question what the frequency actually is for Kingman TAC.
rbuxton
Hesperus, CO
Here's my table taken from from RRDB, FCC ULS, my notes. BOLD is what I have confirmed by monitoring. Plenty needs confirming. Good luck!
Ch 6 Kingman TAC0.000000Search
Ch 7 Dist. 2 Oatman0.000000Search
Ch 8 Dist. 4 Meadview0.000000Search
Ch 10 Dist. 5 Strip East (155.190 not licensed to Mohave County)158.730000 / 155.190 inCTCSS 110.9Hz
Ch 11 Kingman Admin (Animal Control)155.880000 / 154.950 inDCS 165
Ch 13 River154.875000 / 155.610 inSearch
Ch 14 SAR Repeater0.000000Search
Ch 14 Input0.000000Search
V-AIRS4155.475000CTCSS 173.8Hz
U-AIRS#460.375000Search
District 4 - Wikieup ???155.550000Search
UNID Havasu Rptr158.745000Search
UNID Havasu input154.770000Search
UNID Kingman Rptr154.755000Search
UNID Hayden, Christmas Tree, Black Rock158.760000Search
UNID LE158.865000Search
UNID460.250000Search
UNID460.350000Search
UNID Wikieup Rptr Hayden Pk.155.535000Search
UNID Wikieup input153.800000Search
UNID Smith Pk., Aubrey Pk.155.565000Search
UNID LE mobile154.025000Search
UNID LE Scrub Pk.154.665000Search
UNID FB Hayden Pk.153.860000Search
UNID LE FB Kingman154.740000Search
UNID LE Mobile154.650000Search
UNID LE Scrub Pk.155.940000Search
UNID LE156.240000Search
UNID LE154.995000Search
UNID LE FB, MO153.800000Search
UNID LE MO158.977500Search
UNID LE MO154.845000Search
UNID LE Crossman Pk.155.685000Search
avdrummerboy
Mohave County, AZ
I can confirm the inputs and outputs as well as PL's for Ch. 1, 2, 3, 4, 7, 11, 13 and 15. The PL for Ch 13 (River) is 110.9. Still trying to get any close call hits or other confirmations on Kingman TAC, Meadview Ch. 8 and if there is a SAR repeater or if Ch. 14 is the confirmed jail channel.
rbuxton
Hesperus, CO
Take note that the latest table of mine has deleted some of the freqs from the first table. What was SAR repeater (on the first table) is Jail repeater (low power). Educated guess would be that Kingman TAC is a simplex freq. Keep up the good work!
