Motorola MCS-2000 220MHz Version - Was There A Determination On Software RSS/CPS Needed?
Wins411
So long story...short version. I was given a MCS-2000, M01MHL9PW4AN, I can use it as is, I have listed what is in the 28 channels programmed into the radio and it is all stuff local to my QTH, but it is the 220MHz variant I am suspecting is the Indonesian type radio. I have read other forums seen mentions of some sort of Euro or Indonesian type of RSS/CPS for the radio that I cannot find when searching, but I do know it was somehow programmed at one point and time because it has the SK hams call sign still in the radio on power up along with the channels.
So, not asking for freebies, etc per forum rules, but I would like to know knowledge wise, what is the correct software that I need, I have an older computer capable of running the needed items, the RIB, serial cables, USB cables with RIB the works, and possibly the right software but maybe some other factor not working. I have tried the CPS 02.02 and when attempt read, the radio displays CSQ, goes blank with lit screen, and then I get a cannot read radio, and radio resets fine. When I try 02.03 MSC-2000 the radio goes CSQ, then the light goes off blank screen, followed by a FL 01/90 error which I have looked that up as well and seen also in the forums that can be from using the wrong software on it, I assume i need to find the DOS RSS as I have had to do for other type older radios maybe?
The radio still resets with power to proper operation and is not bricked. Just need some actual/factual information to point me in the right direction, otherwise just going to use it as it and roll with it.
Thanks.
K2NEC
NA
What you have is an MOF230, the software is a special windows based LAB version and it's pretty hard to come by
mikewazowski
Forums Manager
Oot and Aboot
The software you are looking for is called Wookie. Someone was clearing out a bunch of Indonesian radios a couple of years ago on eBay and he included the software with the purchase of a radio.
Wins411
Ok, well I appreciate that information, I have a Wookie version 2.01 (SKY) and it actually reads the radio, but I get several issues with it. First it reads the entire radio, but tells me it has suspicious errors, Error invalid data retreiving block emergency block (block discarded) checksum error in block; squelch/privacy (corrected) error: unsupported radio type (check 12m number) unknown radio model, and eventually radio cannot be programmed. Its a start. But I am guessing from experience that I need a clean code plug for this radio to fix all the junk that someone has evidently put there ?
I see one major problem is that the version that I have does not recognize that there is a 220MHz radio at all so guess I need to find the right version of Mobius Wookie? Am I on the right path there? I figured when it didn't show and the channels showing are 120.000 MHz that something is really off.
Wins411
this brings back unpleasant memories ..... wookie .... they should have called that software "wonky".
I completely see what you mean. I assume I have the right version (SDVN4274A) as its the only one I have ever seen but mine does not have any 200-240MHz models in the model RLC/DAT codeplug configuration files and with no documentation I don't know if I am supposed to just add an entry, change one of the entries, etc but i get this drift from the text files with the program. I have been reading info on the RLC program that came with it but no time as of yet to compile a proper input to add to the lab program itself, and not being a Moto guy I have to identify the head on the unit (the same as a type 1 i believe) as well etc. In the end I'll either figure it out, use it as is, or unlike most I have access to an enviromentally filtered burn furnace where it can be disposed of safely :) Too bad there is not a depot of RLC definitions.
Wins411
An update, I have created, compiled with RCL a file for wookie for the radio, i have read the code plug, repaired all errors and re-entered the frequency. I am stuck because wookie still says unsupported radio type check 12m number cannot program. That is the only error left. I believe this to be an error on the band line where i have 220000.0 225000.0 219000.0 i think the base freq. may be off, and also I know the head type is wrong i cannot find one (c,e,h,i,j,L,m) that matches i have the standard 1 row 8 column display that shows on the model 1 pdf in the forurms for the mcs-2000 but no idea what head type this is, even going by designations in the service manual none of them match or work. Anyone have any ideas, is there a force button on wookie I'm missing? Cant find reference for 12M on google and no markings on radio only reference to 12M is product ID but RCL doesn't allow me to edit that?
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
this won't be helpful other than my diluted memory from the mid90s.
there was a special version of Wookie software for these radios in the 220 band.
the normal software would not work.
I do not know if it was a hacked version or ??? -
