Motorola XPR-7550 LTR
zsauve
Oak Creek, WI
I've seen from multiple sources that the XPR-7550 comes with LTR trunking built in however it must be activated when purchasing. How do I go about getting LTR enabled if I buy an XPR-7550 aftermarket & how much would it cost. Also, is there a seperate CPS needed to program the LTR trunking info or is it done through the standard Mototrbo CPS.
S
SARCommCoord
Guest
Contact your local Motorola dealer or contact Motorola directly.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The correct answer is it does through third party software installed on the option board.
You'll have to purchase that software which will come with its own programming software.
Check out Scholer-Johnson (SJI).
com501
The dealer you are renting service through will be able to program and authorize your radio for you without you have to buy the software from Morgan Johnson if he will sell it to you in the first place.
