Motorola XTS 2500 with P25
kflavin
Canton, MA
So I'm hoping someone can help me out here. My dept uses mostly all conventional UHF channels, however for interop reasons we have to add some P25 digital channels to our radios now. I have the radios almost programmed to where I need them. However I'm having issues imputing the NAC's for the digital channels. Under the zone and channel assignment catagory the NAC input area is greyes out. And I'm sure I'm over looking something simple, but if anyone is able to help it would be greatly appreciated. I don't want tk send our radios out if possible.
Clarkcomm
Did you set the personality to digital? Analog and digital personalities have to be different. You can do mixed mode also but you have to set this up in the conventional personality on the RX Options tab. To keep it simple, I assign a digital and an analog personality to start programming.
Hope this helps!
n2hbx
Lady Lake, FL
Make sure you have the TX and RX signal types in the digital conventional personality set to ASTRO.
Larry
KG4INW
Midlothian, VA
Are you sure those corresponding personalities have been enabled for Astro TX/RX? That'll need to be done in the appropriate personality.
Larry beat me to it!
