Motorolla Radius M1225 issues???
biffm17
Naperville, Illinois
Hello there, new member here, i have a Motorolla radius M1225 radio, it used to work, i came across it again cleanin out the grage it now does not, when i que up the mike, it "resets, and the dispay goes out and back on, all symbols on the display and it keeps on doing this till i turn it off and on again again... I am lost.. I found my programing cable, and not the software... any help or ideas, or wtf to do??? Please help!
KG4INW
Midlothian, VA
What size power supply are you using? It might not be big enough. Other than that, sight unseen, it may be hard to diagnose.
biffm17
I have the unit on a good power supply, 13.8v dc unit with a 15 amp constant rating... I did get the issue with the mike cue prob fixed lastnight, bent wire in the rj45 jack, that problem is now solved, but i still cannot get the unit to transmit? I used to use this radio long ago, 05' 06' for ema, and i cant find any of my info on it, or instructions on it either, moved twice, prob thrown away.... Any way to get a users manual for this radio? pdf format if possiable?
biffm17
Antenna is the corect one i had in my old pov, it was with it, and how i came across the radio.... just puzzled on why it would stop working, it was removed and stored, "survived" two moves, and now just a paper weight until i can get a users manual.....
KG4INW
Midlothian, VA
The manual won't tell you much more than how to change channels, adjust volume, turn scan on/off, etc. I haven't been able to find it but here's the service manual: M1225 Service Manual
What specifically are you trying to find out from the manual? A lot also depends on how it was actually programmed as to what is what, functionality wise.
biffm17
Thank you everyone for the quick responces, and the users manual and service guide.... It looks like i'll have to re program it anyway with the narrowbanding.... Thank you all again!
