ProScan: Moving Departments within a System on the SDS100 n' 436HP
Chris0516
Pittsboro, North Carolina
I have Proscan and, normally I would do it that way, but. For some reason Proscan is not cooperating, so. Is it possible to move things, directly on the scanner?
GTR8000
NY/NJ Database Guy
BEE00
No. It's a very simple procedure to shuffle stuff around using ProScan, not sure why you're having trouble (aside from the fact that you always seem to constantly have trouble with something in ProScan).
  • Like
Reactions: wtp
Chris0516
I know I should be able to 'drag n' drop'(I actually prefer that). I don't know why I keep having this particular problem, so. I thought I would try a different route this time.
tvengr
Well Known Member
Baltimore County, MD
If you are having problems with ProScan, try Sentinel. In the favorites list editor, click on the system. Highlight a department or departments and use the green arrows to move up and down.
ProScan
Software Provider
Ontario, Calif.
I think the problem is that ProScan won't allow organizing the departments and sites like this:
department​
site​
department​
site​
They need to be organized like this
department​
department​
site​
site​
Are you doing it like this?
1. Place the mouse cursor over the Department to be moved.
2. Hold down the left mouse button and move the department to the desired location within the set of departments.
3. Release the left mouse button
Chris0516
department​
site​
department​
site​
department​
department​
site​
site​
I don't organize like first example. As for 1-3, yes.
ProScan
Software Provider
Ontario, Calif.
You had this very same issue before.
Are you using the same computer as before?
Can you test the left mouse hold down with a text doument or do a online serach for something like this "windows left mouse select text"
Select Any Text by Dragging the Cursor Over it
This is perhaps the most popular method for selecting text in Windows. You can select text with this method by holding the left mouse button and dragging the cursor over the content. It's a simple and flexible way to select text.
Chris0516
Yes I have had this problem before, and the same computer. I am just going to do 'Copy n' Paste'.
ProScan
Software Provider
Ontario, Calif.
Another thing that you could try is:
Select the department with your left mouse. Hold down the right button instead of the left button. Release when in the desired location.
That will copy the department to the new location. Delete the department copy from.
