Multi site system
MTL_Emergencies
Member++
Quebec, Canada
I'm trying to monitor a multi site P25 system (SÉRAM). Basically I want the G4 to connect to the underground site (site 15) when I'm in the subway (when there's no connection to the other site, site 1).
I programmed the CC (of the 2 sites) into one P25 trunking system list, but I can only monitor site 1.
Site 1 NAC is CF1 and site 15 NAC is CFF.
Would the NAC difference be the problem to why I can't connect to site 15?
The problem isn't the NAC since when you set up the system in the PPS you use CFF (not the site NAC). The bigger problem may be the signal strength. If the signal strength doesn't drop enough in the underground the G4 will stay locked onto the lower frequency (Site 1). One solution is program the system twice, using the CFF NAC in both but only have site 1 in one system and site 15 in the other and have them on two different knobs. Of course, if the signal does drop enough, the issue might be you used the site NAC and not the system NAC of CFF.
MTL_Emergencies
Member++
Quebec, Canada
Well the signal does drop enough to the point that the G4 goes into CC hunting.
Would the issue be that I defined the Site ID to be 1 and the G4 disregards the site 15 freqs since he decodes site 15 instead of site 1 (when CC hunting)?
I posted pictures of the programming.
You don't have Site 15 listed in the site list above, you only have site 1. Add (NEW) site RFSS 1 Site ID F. right now it is only looking for site ID 1.
