Multiple scanner profiles?
W2IRT
West Caldwell, NJ
Hi all,
I now own a BCD996xt and a 396xt, both of which I program with Freescan. I use more or less the same codeplug in both radios (with subtle changes), but I would like to set general options for the radio slightly differently. I cannot seem to find any way to set up profiles on a per-radio basis with Freescan.
Let's say I want to have to have the portable display different startup text than the mobile as an example, or wanted different tone monitoring options in the HT as opposed to the mobile. I'm sure there's gotta be some way to accomplish this. It's also saving all files with a .996 extension. Is this normal behaviour or can it be selectable based on the radio model involved?
rbm
Upstate New York
Yes the .996 extension is normal.
I have more than 40 Uniden scanners 15's, 396's, and 996's. Both generations of each.
In FreeSCAN, I go to the 'Setup Scanner Options' tab and change any options that I want for each model, and then just change the Filename to whatever makes sense to me when I save it.
I also go into the 'Tools' tab and 'System Quick Key Manager' and set the default to be all off. Then I only activate the systems I care about at the time. That's much better than turning off close to 100 systems.
You can also set any combination of SQK's you want.
Rich
rbm
Upstate New York
Here's a sample of a few of my FreeSCAN files from one of my computers.
Many of them are just adding one or two new or updated system files to all of my scanners.
The files in the list below that begin with numbers, are for just one system file and the number is the SQK for that system.
Most of my system file names begin with the SQK number. That makes it easier to keep it all straight. ;)
I have several hundred system files, and many of my scanners are 'tailored' to a specific purpose.
So the systems programmed into them vary slightly. (I've maxed out the memory on even the XT models at one time or another.)
One nice feature of FreeSCAN is that you can just add or replace a system without reprogramming the entire scanner.
That goes VERY fast.
The few times that I've reprogrammed all of my scanners at the same time, even using three computers to do it all has taken HOURS!
Especially the BCD396T's, they take forever compared to the others.
Rich
00_Locals.996
35.996
78.996
79_AsOf_01-09-2014_WithTGIDS.996
79_NewImportFromRR_01-29-2014.996
79_NewImportFromRR_01-29-2014_Updated.996
BCD396XT 12-17-2013_Download_After_Updates.996
BCD396XT 5-15-2014_Cortland.996
BCD396XT 5-15-2014_Cortland_Download_from_BCD396XT.996
BCD396XT 9-22-2013_Downloaded_After_Updates.996
BCT15 11-14-2013_Downloaded.996
BCT15 4-24-2013.996
BCT15 4-24-2013_R7-2.996
BCT15 4-30-2013.996
BCT15 5-8-2014_ComPort14_WithNewFilter.996
BCT15 6-8-2013.996
Burlco_and_NJ_State_10-17-2012.996
Central New York Interoperable Communications Consortium (CNYICC).996
Chemung County Governmental Services.996
CortlandCo.996
Delaware_State-Old.996
Joe_BCD996XT_Delaware_State_After_Rebanding_04-03-2013.996
Joe_BCT15X 05-01-2012 13-02.996
Joe_BCT15X 12-04-2011 14-28.996
Mobiletech Communications.996
Mobiletech_11-12-2012.996
NYSEG_10-11-2013.996
NY_Statewide_Agencies.996
Onondaga_Trunking.996
PA_Medevac.996
PA_Statewide_Agencies.996
Pennsylvania_DCNR.996
Railroads.996
Seneca County.996
TOMPKINS.996
Tioga Downs Race Track.996
To-Upload BCD996XT 09-07-2013 19-44.996
