Heavychevrolet
- Joined
- Mar 17, 2025
- Messages
- 2
- Reaction score
- 3
I cant quite hear people clearly, or there talking is soft. And static prob from truck or something constantly but when i trun the sq i cant hear them or static. I have a old dx33hml galaxy radio, with a astatic swr and power meter PDC2, with a bed hole mount, 3 foot fire stick and both channel 1 and 40 is 1.7 swr when I adjusted the antenna. Current ground wire is 12 awg, I'm trying to set up a second ground with 8awg there 10ft long to frame. I think my internal speaker is busted so I'm currently using earbuds, I'm getting an external speaker off amazon. The ground wires is hold onto by a bolt and lock nut, i coulndt get a screw going, but i tighten it really gooood hahahaha. I'm currently running power from cig and later on going to tap into fuse box or the battery, I don't know which is better. I have rf gain all the way, low rf power, high band, band e/D, e tone both dials to the middle, NB/ANL ia better on, i move the sq around until it's enough to hear, trying to run cb freq. I put put about 2 watts. I have a 2002 2500hd silverado lt crewcab 6.0l 4wd. I put gear oil on the ground terminal ring so it doesn't rust the frame that I sanded. Running rg8x coaxle. I opened the radio since internal swr meter was falling inside it and have pictures of inside. Running out tomorrow for a bigger ring terminal for 8awg. So I just rigging this thing, cause i have no clue what im doing, only knowledge from internet or people from stores i went too, awful at being electrician. Thanks yall!!
