In a portable situation, a 6 to 12 foot jumper of RG6 would have lower loss, would be better than 25 feet especially on 800mhz. But you want it long enough to be practical, and you want to run the coax away perpendicularly from the antenna elements for at least a few feet. Don't let the coax hang down near the elements.
Reminder about 300 mhz and above - the antenna while being a decent match for rx only, still has lobes that look upwards, rather than outwards.
If one really wanted to have some fun, while keeping in mind the pattern compromises, you could turn it into an ocfd groundplane. That is, the long section would be vertical of course, and at least two, preferably 4 "radials" 18 inches long horizontally. That way you could bring your coax down vertically instead of having to run it away perpendicularly. Still using the balun of course. And still a compromise, but this antenna is about fun, not perfectly engineered.
