Need help Hytera rd982S
Sgtgm
I appreciate everyones input above and have tried everyones suggestions so far other than this last one.I have ordered a factory Hytera cable and just waiting for its arrival.I will update the thread when it arrives.Hopefully that is the issue.I have tried several different computers and software and driver combos and all are showing a usb not recognized in windows issue so hopefully the factory cable solves the problem.
jasej
Hidalgo Texas
The simple homemade cable I showed you earlier works very well. I made it, and it's the one I use most often. I read and write correctly, and when I need to update the firmware, I use the microphone method I described earlier!
You shouldn't have any problems at all.
But anyway, it's great that you ordered an original programming cable.
Let's wait to see how it works for you when you get it. If not, you'll tell us what you find negative again.
Let's hope not!
Best regards.
Sgtgm
Go buy a Hytera PC47 cable. Atlantic Radio has them in stock for $44.95.
Did you try the driver I recommended ?
Took your advice cable from them is on it's way.Let hope that solves all this BS
Pittsboro IN
There have been times when I cloned 3 or 4 radios and then the PC droped the usb port connection. I moved it to another port and CPS was happy again.
Sgtgm
Tried that as well.Should have a factory cable shortly will update the thread on the progress or lack thereof.
Pittsboro IN
When I was with Bearcom I had a port shut down from Trbo CPS and nothing saw it for the rest of that rental period.
It finally cleared up 4 or 5 days after I got home and spent some time with the disable / remove / rollback / search for new hardware routines.
Sgtgm
Have to pick it up at depot yet.Should have it just after Thanksgiving.Will update when it arrives
