Need help: Programming scan in astro spectra
Good Day Masters!
I would like to ask some information and proper method in programming SCAN in ASTRO Spectra using ASTRO SPECTRA CPS.
Need to program all my channels and talkback to any channel. Instead of choosing to every channel, this thing will help us a lot in monitoring.
Please help me and thank you in advance.
rescue161
KE4FHH
Hubert, NC
You just create scan lists with the cannels that you want. I think it is normally 10 channels per scan list. Then you have to add which ever scan list you want to scan to each channel. It is easy, but it is nothing like a scanner. The Astro Spectra will not scan every channel in the radio in one full sweep, unless it has 10 or less channels in the programming. Use the help menu in CPS as it contains how-to videos and explains things very well. Good luck!
