Need help with WIN95 software for Pro95
alross
The "help-button" is grayed-out on the software I downloaded, where can I get instructions for using this program ? Don't see any info on sight !
Thank You, AL
Colin9690
Delaware County
Lewis Center, OH
I find it pretty easy. Click on the 'Channels' tab then, you just select the bank you want to program, then in the frequency field where it says 0.00000, that's where you enter your frequency. And the blank space next to that is where you type in the text tag. When your done, you can go to "Scanner" at the top margin of the screen, and select "Upload".
Hope This Helps,
KE5BCP
Analog Man
Lewisville, Texas
Win95 writes the entire file to your scanner. If you only had entries in bank 6 and left the rest empty, that's how it would have loaded it to your scanner.
