Need Help
RES27CUE
Philly Metro,PA
Ive recently got my hands on a motorola xts1500 700/800mhz i want to enter these freq.s if threre only as discribed not with other activity like police just fire,ems and on event10 penndot. i had entered the freq.s on this site but are only receving police and ems and once in awile a fire chat on event6 but it bounces around if anyone can help let me know thanks.
DEC HEX Mode Alpha Tag Description Tag
3280 0cd A EMS DISPATCH EMS Dispatch EMS Dispatch
3312 0cf A EMS Hail EMS Hailing EMS-Tac
3344 0d1 A EMS ER 1 Hospital ER Notifications (also avail. for on-scene tactical use) EMS-Talk
3376 0d3 A EMS ER 2 Hospital ER Notifications (also avail. for on-scene tactical use) EMS-Talk
3408 0d5 A EMS ER 3 Hospital ER Notifications (also avail. for on-scene tactical use) EMS-Talk
3536 0dd A EMS Ops EMS Operations (Unit-Unit) EMS-Tac
4048 0fd A EMS EMERG EMS Emergency Button (Orange) EMS-Talk
21072 525 D HOSPITAL ADM Hospital Administration (Countywide Net) Hospital
East System Fire Talkgroups
22448 57b D FIRE DISP E Fire Dispatch East Fire Dispatch
22608 585 D FIRE REG 4 Fire Region 4 Fire-Tac
22640 587 D FIRE REG 5 Fire Region 5 Fire-Tac
22672 589 D FIRE REG 6 Fire Region 6 Fire-Tac
22704 58b D F POL EAST Fire Police East (Traffic Control Operations) Fire-Tac
West System Fire Talkgroups
22416 579 D FIRE WEST Fire Dispatch West Fire Dispatch
22512 57f D FIRE REG 1 Fire Region 1 Fire-Tac
22544 581 D FIRE REG 2 Fire Region 2 Fire-Tac
22576 583 D FIRE REG 3 Fire Region 3 Fire-Tac
22736 58d D F POL WEST Fire Police West (Traffic Control Operations) Fire-Tac
Countywide Misc Talkgroups
2928 0b7 A MCCF TRANSP Montgomery County Correctional Facility Transports Multi-Talk
2992 0bb A EVENT 5 Event 5 (assigned as needed) Interop
3024 0bd A EVENT 6 Event 6 (assigned as needed) Interop
3056 0bf A EVENT 7 Event 7 (assigned as needed) Interop
3088 0c1 A EVENT 8 Event 8 (assigned as needed) Interop
3120 0c3 A EVENT 9 Event 9 (assigned as needed) Interop
3152 0c5 A EVENT 10 Event 10 (Rt. 309 Project Interops) Interop
Septa3371CSX1
Drexel Hill, PA
This is the Montgomery County system he is reffering to BTW. Most likely the bouncing around you refer to is the digital noise from the digital transmissions that the fire talkgroups use. I have a Pro 97 and I can hear most of the police, EMS, and misc. stuff on the system but the fire and digital police all I can hear is digital noise. If you want to be able to hear the fire stuff, you need to have an APCO-25 compliant scanner (i.e. Pro 96/2096, PSR 500/600, BCD396/996T). Most likely the radio you are using is not APCO-25 compliant and it can only receive analog. Hope this helps out.
RES27CUE
Philly Metro,PA
thanks for the info my radio is a xts1500 700/800mhz 9600 baud rate, APCO Project 25. FM-Intrinsically Safe. flash code 5000080004882. my only problem i only want to listen to fire and ems only do you know how i could do that.
n3obl
Ø
PA
in order to program a radio on a motorola trunking system...
1. you must be authorized.
2. need to have the system key....
Frank
hippieman556
Philadelphia,PA
yes you need the system key otherwise it will only do digital bounce and the radio might be non digital as others have it is better to hey a pro 96 and listen to that
