Was woundering what the best base antenna would be for my Uniden BCT8 Scanner
V VanGorden86 Member Joined Feb 8, 2012 Messages 2 Reaction score 0 Location Lindley Ny Feb 8, 2012 #1 Was woundering what the best base antenna would be for my Uniden BCT8 Scanner
Rt169Radio Member Joined Aug 24, 2011 Messages 2,984 Reaction score 105 Location CT Feb 8, 2012 #2 What kind of freqs do you want to listen to? Are you looking for a outside base antenna?
V VanGorden86 Member Joined Feb 8, 2012 Messages 2 Reaction score 0 Location Lindley Ny Feb 9, 2012 #3 i mainly listen to low band but i guess in a year or two they are going to switch everything over to highband mainly listen to fire ems and police
Rt169Radio Member Joined Aug 24, 2011 Messages 2,984 Reaction score 105 Location CT Feb 9, 2012 #4 Well then here are a couple of good outdoor antenna choices. First there is the Diamond D-130J,I have this antenna and it works good and its built tough. Diamond D-130J D-130NJ Discone Antenna Then there is the Antennacraft ST2,this antenna is not as sturdy as the Diamond discone but people say its a really good scanner antenna. Antennacraft ST2 Scanner Antenna, Antenna Craft ST-2 Now those two antennas are just the two mainstream antennas for scanners,there are others that you may like better.
M methusaleh Member Joined Feb 18, 2009 Messages 361 Reaction score 1 Location New England Feb 10, 2012 #5 As others have asked already... What band(s) do you want to listen to? Base or mobile antenna? Any considerations regarding size, polarization, stealth, mounting limitations, coax feedline run length, etc?
