Needing More Help with Identifying the Talkgroups for UCA p25 700mhz
Brejames1
Anyone heard any more traffic on the 700? Now that most of the southern 2/3s of Utah now with Tooele and Box Elder later this week. Anyone got ideas on some of the talkgroups?
We have some up in the air with all the 63xxx patch TGs its making it harder to identify the real TGs
And there is only a few of us trying to identify for the whole state so it would help even if your not from the area to help with these TGs. SL county area and Utah county area will be end of November and first part of December, So until then we need help identifying these TGs.
This system should use the same entities as was on the 800 system so it should be as big or bigger than 800 was.
good points i'm trying to ID 82755,63786,63759 on my sds200 thank you...along i15 in Utah yesterday thank you
kirkco
Erda, Utah
I'm not sure how to submit TGs, but again, West Valley PD 2 is 2881, confirmed.
Thanks for the update on 2881. I've got it logged and will (eventually) submit the change if not already done at the time. I usually run (scan wide open) for a month or two to capture data/verify and then submit any new finds (in SL Valley/Tooele and surrounding areas).
