OK I'm stuck I need to mount an antenna neer power lines. How far do I need to be from it I may have 5ft to the left but that's where the line is
If you need to mount an antenna NEAR power lines, there's a simple rule.I may have 5ft to the left but that's where the line is
Wilson Yagi 301111
I would NOT run the coax parallel or near the power line. That will induce electrical NOISE into the receiver. BAD idea.Mast will ne on the ground maybe 6" in for support antenna will only be maybe 5foot above roof
here is the image it failed to load
800 its a Wilson Yagi 301111
I do have a lightning suppressor and will connect to house ground till i get my rod installed
Here are the specs for various types of coax. Click on "Details" to see the specs.
Coaxial Cable by the foot
Mast will ne on the ground maybe 6" in for support antenna will only be maybe 5foot above roof IS-B50LN-C2 is the resister I have and Im using LMR400 to the suppressor and lmr200 flex 5ft to the radio Id need more LMR200 flex like 10ft not sure what the loss would be or is there a lower loss flexable cable to run from the surg to the radio?
other side would require a new rod
Here is a better rough diag all grounds bonded to ac ground rod. surge arester and pole bonded to ac ground
Not a fan of driving a grounding rod. done far to many
Personally I wouldn’t put anywhere near a power line.
Odds are you might do all that work and might not pick up nothing but white noise do to the line.
Then you’re back to square one.
Maybe at HF but not at 800MHz.
