new DSP upgrade is available for Pro-96/2096
royalzapper
Hamilton County [Ohio]
Reverting to the factory DSP
In the PRO-96/2096 DSP APP U1.4 Upgrade
Dated February 18, 2007
[Reads]
Reverting to the factory DSP firmware version
"If for any reason you decide that you would like to revert to the
original factory DSP version (F1.1 or F1.2, depending on the age of your scanner),
you may do so by pressing 0, then PGM, then CLEAR,then ENTER during the
“Welcome” screen. Note that this will permanently remove the upgrade from
the DSP flash memory. You can reload the upgrade as many times as you like
using the upgrade utility."
Note: It should be "press 0,then CLEAR,then ENTER
is will revert your scanner back to the factory installed DSP
Your scanner display will show
Reverting to
Factory DSP
Please Wait
Power Cycle <- this means to turn your scanner off then on again
royalzapper
Nasby
Ohio
Just did the update and have been listening for a few hours. It seems like a real improvement on the Summit County, Ohio / Akron, Ohio digital system.
Pro-96 rocks!!!!!!!!
N8IAA
Fortunately, GA
A definite improvement on two systems I listen to in N GA, Forsyth County and Hall County. Connects to the digital signal faster and holds it.
Larry
902
Downsouthsomewhere
Just loaded mine. I'm not hearing any digital noise at the beginning of transmission like I did with 1.3, but it did open up once during the digital hang time at the end of transmission. I'll give it a few more days to see how it goes, then try to get to where I can hear a 9600 P25 trunked system; see how that sounds. So far everything I hear has been "wide pulse" ASTRO, not full P25 compliance.
Worst case, I'll load 1.2 back in. More to follow.
chodell
Hedgesville, WV
Eastern Shore System -- same problem as 1.3
upgraded to 1.4 on my 2096 and it has exactly the same problem as 1.3 with the occasional 'digital hash before decoding' issue. It seems to happen about every 10-15 transmissions with a channel paused, so it is not an issue of different systems or ids. Squelch setting makes no difference (as i would have guessed). I haven't tried on the 96, but I can't see any reason to make the switch. going back to 1.2 which seems to work the best of the recent attempts.
D
DaveNF2G
Guest
All of my digital monitoring so far is on conventional channels. I'm still waiting for one of the local trunked systems to begin its planned transition to digital.
In the meantime, my PRO-96 has not given me any trouble under any firmware version. Digital decoding is fast and clean, as long as the signal is reasonably strong.
Colorado Springs, CO
Meh...
I saw little to no improvement when it came down to initially decoding APCO-25 transitions on a CQPSK system within El Paso County Colorado. Maybe 1.4 is a little better, but its hard to compare without 2 pro-96's.
prcguy
On my PRO-96, DSP 1.3 would not decode about 1 in 10 LAPD transmissions and DSP 1.4 is improved with about 1 in 20 not decoding. I may go back to 1.2 with slightly worse audio but at least there are no irritating noise bursts.
prcguy
SLWilson
Ohio
Ohio MARCS
I monitor the Ohio MARCS system with my Pro2096.
After I added ver 1.3 I had several instances where the scanner just "didn't decode" the voice (so all I heard was the digital noice, like I wasn't using a digital scanner but programmed a CC freq in to it) many times.
Since the upgrade to 1.4 that has only happened once....
Steve/Gallis:confused:
sdyer
which version
How do you know which version you have ?? Sorry for the question, I have only has this scanner a couple of weeks. Not used to this Digital scanning :( Thank you all. This forum helps.
unixdude
The PRO-96 is a great scanner, and once you get used to it, you'll probably come to love it.
The unit has many power-on key sequences to get or set various values or settings, all of which are documented in the manual. To see software versions, press "3" when you see your welcome screen.
Spleen
Baltimore, MD
Seems like no effect so far on the Baltimore system. Hasn't cleared up the occasional motorboating, but hasn't made it worse. Someone who travels a lot or lives outside the city who may be getting less than optimal reception may want to give it a try, though...
ticoman71
Atlanta, GA
Much better...
Good job RS on the upgrade.....I still get the issue with undecoded digital noise but is not as often as before. I have the 96 with the 800 MHZ RS antenna and monitoring Cobb County, Georgia.
Thanks again and please keep those upgrades coming.......
pinetree
Felton DE
The 1.4 upgrade makes State of Delaware system seem better especially Dover AFB, but a problem developed in a Pro2096. We have a Voice channel in Kent Co that has a carrier which has developed in the system. Ver 1.4 caused the scanner to hang on that channel. I installed ver 1.2 and the problem is corrected. Ill try 1.4 again when the system is fixed.
brandon
SoCal
Tried 1.4 but it doesn't work very well. I am listening to LAPD and Pomona ICIS and get lots of digital bursts. Also had this issue with 1.3.... back to 1.2 for me since it worked the best.
unitcharlie
a Kentucky DB Admin...
far from Nonesuch, Ky...
I have reverted to 1.2 as well.... slight improvement in some of the agencies I monitor but it made Kentucky State Police almost intolerable.... not decoding as many as half the transmissions i needed to hear... 1.2 is clear as a bell.
