New Fire TG on Morris County MIRS...
APX8000
Sarcastic Member
AES-256 secured
New wildcard popped today...TG 34320...New Vernon FD Engine-3 (RID 55652) calling County. County responded as well (new RID 60185 never seen before, but the 601XX series RIDS have been associated with the 911 EMERG TG 16). Any ideas?
KDD904
Northern NJ
That is not a MIRS talkgroup, but another one of the fire response talkgroups, Fire Response 5. The 6xxxx ids are dispatch positions.
APX8000
Sarcastic Member
AES-256 secured
Maybe I should have been a little more specific...When I refer to MIRS, I'm actually referring to the Morris Interoperable Radio System (Motorola UHF trunked analog/digital system) not the MIRS-1 talkgroup.
I'm aware that all of the dispatch positions are 6 series. I actually have over 1200 LIDS alpha-tagged on the system. What I was saying was the 601xx series RIDs have only been associated with TG 16 in the past, which is the 911 EMERG talkgroup (emergency button on radio). I've never seen a deviation from this (see below).
Is there now an active FIRE RESP 5 talkgroup using DEC 34320 and have agencies switched to it? If so, which ones?
This is how the RIDs are layed out on the console by talkgroup...
602XX CG COMM
604XX LE COMM 2
606XX FIRE RESP 3
608XX PP CH 4
610XX MIRS
612XX MUN PD 4
613XX MUN PD 5
614XX MIRS
616XX MUN PD 6
617XX EMS RESP 3
618XX MUN PD 1
619XX FIRE RESP 4
620XX MIRS
622XX MIPD-4
627XX MIPD-3
628XX MIRS
629XX MIPD-2
631XX MUN PD 1
632XX MIFD-2
633XX MUN PD 2
634XX CG 1
639XX MUN PD 3
642XX EMS RESP 2
643XX FIRE RESP 1
647XX EMS RESP 1
649XX MIOP-2
651XX MIFD-1
653XX FIRE RESP 2
W2SJW
Senior Member
Northwest NJ
Sorry to be pedantic, but the proper name of this system has been discussed many times before - it is NOT called MIRS. It is simply the 'Morris County Trunked Radio System'.
MIRS is the name for the interoperability radio communications plan put into effect by the county when they built the system, not the name of the entire system itself.
[/soapbox off]
Have a good day, gentlemen! :D
APX8000
Sarcastic Member
AES-256 secured
Time for me to step up on my soapbox....
Since the system was developed and maintained by Morris County OEM, a quick visit to their website shows the following...Click on the link below then click on "MIRS Information Pamphlet." On the cover sheet it specifically says...M.I.R.S....Morris Interoperable Radio System...that is where the acronym MIRS came from. Morris County NJ USA - Office of Emergency Management
I guess if MIRS was the "plan", they would call it MIRP.
Off my soapbox now Scotty boy...:)
W2SJW
Senior Member
Northwest NJ
Now I'm really confused as to what to believe - I have an acquaintance that works for the county & is directly involved with the day-to-day operations of the system.
I usually take anything else I hear about the system that didn't come from him as blasphemy... :D
RocketNJ
Pequannock, NJ
You can call it whatever you want. It was originally designed as a system to be shared between all county agencies for interoperability between county agencies only.
It morphed around 2005/2006 to have all towns have radios on the system for interoperability only.
Then towns dispatched by the county started migrating over to get off the aging low band systems.
So you can see how the name could have changed, depending on "when" you named it. Either name is correct.
W2SJW
Senior Member
Northwest NJ
Well, color me corrected! :D
I have one last question - the naming of the FD & EMS talkgroups. Are they now referred to as 'Fire Response' & 'EMS Response', instead of 'Municipal FD' & 'Municipal EMS'?
I just want to make sure the database is reflecting the proper naming if they did change...
APX8000
Sarcastic Member
AES-256 secured
What are you guys usng for your Muti-Site High/Low threshold when monitoring the system? I had mine at 88/95 and I found it's holding a site just a little too long when a better one is available. Just bumped it to 90/95 to give it a try on Monday on my commute.
W2SJW
Senior Member
Northwest NJ
Sorry, I don't own any GRE equipment. I monitor the system with an HP-1, a 396XT, or my APX (mostly the APX, as there's nothing better than genuine RSSI to handle a multi-site system like this).
RocketNJ
Pequannock, NJ
Actually KDD904 is correct. It is the Morris County New Jersey UHF Trunked Radio System.
MIRS are the interop talkgroups on the system. There are many talkgroups that are not interop.
See attached pic.
W2SJW
Senior Member
Northwest NJ
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9930; en-US) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.163 Mobile Safari/534.11+)
That was me - you submitted the RID's, but not the talkgroup (34320). Memebers are free to log RID's in the Wiki for the system themselves (we do not add those to the database).
Sorry for the confusion!
