New Jersey Interoperability Communication System (NJICS)
rr60
4735 Comm 7 - MedCentral South Region Operations showing encryption full time on UT. DB has as TDMA. Site 28
GTR8000
NY/NJ Database Guy
BEE00
Folks, please remember to submit any necessary changes in the usual manner, vs simply mentioning stuff in the forums. Too many threads and posts for admins to keep track of. (y)
CastorLB
TG 4769 and RID 2470146 would fit in with Atlantic.
RID 1230121 would be a Middlesex County unit, or Middlesex based unit of some kind.
RID 1230121 is a Rutgers New Brunswick PD radio. I still have no handle on the 247xxxx units as they're usually encrypted TGs but I have seen one pop up on MedCentral occasionally.
rr60
Browsed NJICS from Site 7 all the way South to Site 5 (Hammonton) and sites in between looking at peers with this AM's band opening. No other STS trailers seen. Here is peers for Site 5. Loving UT @RadioDitch
87559
RadioDitch
Field Operations Member
Not Where You Think
Did you check Bordentown Simulcast also? Cause if Bordentown is no longer showing Site 37 as a peer, that means STR-I has more than likely moved on and is fair game anywhere in the state.
RadioDitch
Not Where You Think
It would appear that the Newark Fire RID plan has changed somewhat with all the apparatus purchases since it was last updated in the Wiki. Lots of RID's in the 714200-714499 range showing up. Looks like Rescue 1 and obviously the consoles remain unchanged.
de784
Delaware
It would appear that the Newark Fire RID plan has changed somewhat with all the apparatus purchases since it was last updated in the Wiki. Lots of RID's in the 714200's showing up. Looks like Rescue 1 and obviously the consoles remain unchanged.
Is this a trend now ems going encrypted
RadioDitch
Not Where You Think
Also of note, and not intended to start a debate (please), NJTPD North seems to now be Te. It's swapped back and forth between secure and clear most of the week. It's been submitted.
nosoup4u
High Bridge, NJ
I would argue that this more of a case of the user accidentally turning it off and not realizing it.
RadioDitch
Not Where You Think
More than plausible. There were a few nights where everything was unsecured, even if just for a series of transmissions. But either way, safe to say it's not strapped, it's selectable. Still worth the update to Te.
rr60
RWJ South Ops is NOT encrypted,haven’t seen or heard it on any of their channels over Bordentown.
@elias1988 you are correct, As a new user of UT I made error thinking XP was Enc. This remains in the clear and it was cross patch I saw went back and checked logs. DB correction has been submitted.
RadioDitch
Not Where You Think
P4 is what you're looking for in Unitrunker on the NJICS to indicate encryption. XP is just an indication of a patch.
kd2pm
TETRA Techie
East Windsor NJ
Correct. Not fully strapped yet so it will happen from time to time. Its a work in progress.
RadioDitch
Not Where You Think
Union County Simulcast, new or unidentified TG.
87716
And apparently North Plainfield has access to Plainfield on the ICS. That's a new one to me.
87717
rr60
Yes and yes. Both the FD & PD for interoperability to Union County.
FD has many NJICS Fire & EMS TG’s for true interoperability and lot’s
of other freq’s too.
I have 1814002 on Plainfield too and a couple of hits on the unknown TG. No RID.
Nice catch on the RID @RadioDitch
