New Jersey Interoperability Communication System (NJICS)
howie38
Pemberton NJ
I've got a P25 2 scanner and the NJICS was recently reloaded with NJICS.
Is there any difference with the programing now that I'd have to redownload the programing again from RR?
nosoup4u
High Bridge, NJ
Since there has been some major changes over the last several months, I'm looking for Unitrunker files again from around the state, so I can merge all the ID's into my list. I have also stopped generating 800 only ID lists and I have renamed the ID list to NJICS-ids.txt, which can be downloaded from Index of /scanner_files/
couchm
I noticed there's been frequencies added to the Cumberland County Site but I don't see that listed in the changes log. So I tried to download the whole system to update my unication however it says invalid imput string when trying to import the sites/frequencies but the talkgroup file works fine anyone have any suggestions?
couchm
I had to open the file in excel and remove the "C" added to the control channel in case anyone else has the same problem.
albertspiegel
I'm in northern Bergen county. I haven't been paying close attention but seems I stopped hearing NJICS about a week ago. Anyone else having the same problem? I normally hear lots from Alpine. I am also monitoring Meadowlands and Passaic - nothing. Any thoughts?
CqDx
US
I can monitor Alpine and West Orange and haven’t noticed anything different in my receptions the last couple months
NYC
For NJICS now, do we need to have all the frequencies for a Site programmed, or should just the Control frequencies still work? I ask this because ever since I programmed in Parkway (State PD) TGs for NJICS (for Sites from Union to Monmouth County), I don't seem to hear as much activity now. Do I need to program the Non-Control frequencies too for each Site?
GTR8000
NY/NJ Database Guy
BEE00
You don't mention what scanner you're programming, but most modern Uniden and Whistler scanners only need the control channels to scan a P25 system. Keep in mind that the GSP talkgroups may not be active on the sites you're scanning, or may only be active sporadically.
NYC
BCD436
GTR8000
NY/NJ Database Guy
BEE00
You only need to program the control channels. No guarantee that you're going to catch all of the GSP activity, totally depends on which site you scan most frequently and how active the talkgroup is at that site.
joey123
nj
Is it my scanner or my location that I cant hear system transmission skips a lot and I miss transmissions I’m in Burlington county nj near the moorestown mall I’m using the bc436 hand held Which site should I be using
kd2pm
TETRA Techie
East Windsor NJ
Since you have a 436, just let the scanner scan the system. I dont know that I would go as far as locking out all the sites that your scanner cant hear. The difference in the scan and capture may not make a difference by lessening what it has to scan. I take it you are programming the scanner using sentinel so just add in the NJICS system, make sure all the service types are checked and listen.
From your location you may be able to hear the Berlin Simulcast, the Cinnaminson ASR or the Bordentown Simulcast.
howie38
Pemberton NJ
Is it my scanner or my location that I can't hear system transmission skips a lot and I miss transmissions I’m in Burlington county nj near the Moorestown mall I’m using the bc436 hand held Which site should I be using
I have a 436 also, but even my 996 requires me to locate the antenna into certain windows. IE front living room window will receive the NJSP Berlin repeater really well with the Cinnaminson tower most of the time. But if I stick it in the back bedroom I get the Bordentown tower, even though it's on the opposite side of the building from Bordentown. I can receive the TP, but have yet to get GSP, and I'm in Pemberton!
Also found that the shorty antennas work a heck of a lot better than those telescopic or rubber ones. This is what's working really well for the 436....
AEcreative Wide-Band Scanner Antenna for Uniden SDS100 BCD436HP BCD396XT BC346XT BC75XLT BC125AT BR330T Whistler TRX-1 WS1040 WS1080 RadioShack Pro Icom IC-R30 IC-RX7 AOR Alinco DJ-X11 DJ-X7T BNC SMA
rr60
Site 62 (858.70625) is appearing as a peer to the Bordentown Simulcast. Is anyone else seeing Site 62 as a peer to any other sites in the system down there? I notice that it's not appearing in @Audiodave1 screenshot of the Berlin Simulcast peers, which it should be if that is the new Atlantic Cape Community College site near the airport.
Yes I have Site 62 and now a Site 57 both off 03 Bordentown. These are not peers of Cranbury nor Freehold. I am unable to tune direct (no signal). On the SDR spectrum display zero trace .44375 and just barely a trace .70625. Maybe some tropo tonight.
joey123
nj
Now my sds100 scanner is acting up with njic system when it scanning its skips channels and some times it’s shows no bars on it does it have to have the correct tables on it to work
