New to CB and New to the Forum...
krokus
Southeastern Michigan
A transmitter like that could punch over a KW input with a pair of 4-400s.
the 4 jugs glowing purple are power supply rectifiers.
No clue what the top tube would be.
My Big Bertha equivalent had 6 purple glowers near the bottom, 10 KV at over 1 amp.
3 phase 220, 20 amp/phase just to turn it on.
Final is a 4XC-5000.
That looks a lot like the AN/FRT-39 that I had training on. Which was funny, as nobody had them installed at an operational base, as hey had moved on to the FRT-96.
jcrmadden
It had only snowed a couple inches when it turned to freezing rain, and everything got a 1/2" layer of solid ice.
If the wind had picked up or if it had cooled a couple of degrees and turned back to snow, the extra weight would have brought a lot of trees and lines down.
Luckily it went the other way. The wind laid a little and it warmed a couple degrees, turned back to rain, and melted most the ice off during the night.
We were prepared for worse, but we're glad it wasn't.
I had filled and ran the generators the day before, plus had extra fuel and propane laid by in preparation.
It has definitely been a good couple days to stay indoors though. Finally took time to wipe down the guns, sharpen some steel, and oil up the boots.
T680
When I was in training my days usually started with around an hour if driving before sun up with it raining and just above freezing. That which didn't kill me made me stronger, and made for some good pic of an ice covered grille.
slowmover
Fort Worth
Easter Sunday, 2025
Where I’m parked under the shade of pecan, cedar elm, red oak & pin oaks near the Brazos River. Beautiful place.
One of Texas most scenic rivers.
But we’re inside the immediate flood plain.
My truck & trailer would disappear in the waters as seen from higher ground across road in 2021.
I’m expecting my truck CB to be of help when we get warning ahead of time the upstream lake dam goes to release. Hitch & Go! (Many hours before crest, but zero reason to dally).
I would be among several hundred in my area looking to get past a couple of choke points headed out.
Maybe there’ll be others with radio. Just one other man with a decent rig can make the difference.
Ask the OP his opinion now he has high performance 11M gear.
Seat belts, concealed carry . . . and Citizen Band.
niceguy71
Massachusetts
don't even get me started on Seat Belts...
back around 94 they were pushing and pushing and PUSHING for it to be law in Massachusetts I held signs at voting places as it bothered me that much.... we voted it down a few times before it got approved in 94
I knew sweet mothers that even voted for it???? and they never wore their seat Belt and hated the damn things..... so I said why are you voting for it then??? and they said I want my kids to wear them????
at first the seat belt was only a secondary violation, so they had to pull you over for something else and catch you not wearing it before giving you a ticket and 7 years of insurance surcharges.
but now if they see you without it, they can pull you over and ruin your life.
all the cops I know never wrote anyone up for it... until the state started pushing campaigns to wear it ( Click it or Ticket) and it was mandatory in 2006... they actually had road blocks on the quiet main street.. you are in a long line of cars????? and someone in a suit up ahead talks to the driver of each car then it pulls forward...... when that guy points to a car .. a police officer points for him to pull over up ahead around a bend where no one else can see what is happening.... they caught thousands of people that way
I drive mostly to and from the post office / grocery store.. I hardly do over 30 MPH ... if someone wants to wear it.. then wear it but don't tell me what to do!!!!
I do wear it on the highways.. it's great, it makes me feel invincible and I then drive around 90 MPH talk on the CB and eat my lunch... unless I forget to put it on ..then I'm more cautious and drive right at the speed limit with no lunch.
ok now that my blood pressure is back to normal and the smoke has stopped coming out of my ears.... I'll stop typing.
everyone is allowed their opinion... that's just mine
Hdc30474
I would suggest also running the negative lead all the way to the battery. Bonding ( low resistance electrical connection) of metal parts on vehicles is sometimes unreliable. The battery negative post will be bonded well to the engine and at least to the nearby frame if nothing is damaged or loose.
Unless you have a weak battery and leave the radio on in receive for days, it should not drain it too much. In receive it probably draws no more than 1/2 amp and likely much less than that.
The antenna base where the coax cable connects, needs to be bonded to the largest part of nearby metal of the frame. Magnetic mounts do not provide an electrical bond to the vehicle at the antenna. Metal hoods and quarter panels may not be bonded at all to the frame.
I also see people with Jeeps mount antennas on bumpers and tire racks very close to the vehicle. This not only blocks signal, but greatly detunes the antenna.
You MUST place a fuse on the positive lead as close to the battery as possible. The wiring from the battery may get damaged and short out to the frame. This could cause an electrical fire.
slowmover
Fort Worth
Recommended:
www.k0bg.com
As you put together today’s state-of-the-art:
Hdc30474
Recommended:
www.k0bg.com
Good site with lots of info.
I didnt want to get too detailed, but unless you bond every part of the frame and outer shell of a vehicle with grounding straps, parts will be at different potentials and may be a poor contact point for the negative lead of radio equipment or antennas grounds. I have had this issue a couple of times. Car makers are not interested in making sure car parts are well bonded together since 12 volts DC is not the same concern as 120 volts AC or more. Have you ever slid into the seat of a car on a cold dry winter day, grab the door to shut it and get zapped! The door isn't bonded to the rest of the car. There is some level of connection through the door hinge. I had an Acura that I learned to hold the door as I sat down. I could have put a grounding strap on the door, but I learned a knew habit. Hold the door as I sat down. Sliding into the seat created a static electrical charge which discharged through me when I touched the door to shut it. Sometimes it was enough to make my figures hurt.
Obviously it gets challenging at times with HF radios and all the modern electronics and ignition systems. This is quite different for aircraft. Especially with jet aircraft who's generators produce 115 VAC at 400 Hz. Not only is it a RFI issue, but a huge safety issue. Also an issue with lightening discharges near the aircraft.
I installed an HF rig in my 2017 Ford Explorer and of course had noise issues. A Ford Explorer is an SUV built similar to an F-150. I had concerns going into it that I had a challenge ahead.
Once I connected the negative lead directly to the battery, it went away. It saved me time in trying to figure out what parts needed to be strapped to stop the noise.
I was lucky with the antenna, I did find a good point to strap the antenna bracket to at the rear of the vehicle that worked well. It was the mount point for the rear tow hook.
Hdc30474
Something I had not considered. Because newer vehicles have a charge/current sensor connected at the negative battery post, try to locate where the lead from the negative post connects directly to the frame and connect your radio negative lead there, in order for the current draw by the radio to be included in the measurement by the sensor. This is essentially the same as connecting directly to the negative battery post instead of anywhere else on the frame that may not be bonded well going back to the battery. I have not done this on my Explorer and never have had a battery charging issue. With a CB radio only drawing a couple of amps at most transmitting, it is probably much less an issue than my HF rig drawing up to 17 amps with 100 watt transmit power. In my installation it apparently does not matter. My current battery is 4 years old and still strong, and I have had no check engine codes or any other problems. Other vehicles may be affected.
niceguy71
Massachusetts
everyone here say's to ground the Radio as close to the radio as possible... not to the battery. always take the power from the battery ( with a fuse and a relay so when you shut off the ignition switch it also shuts off the Radio) it sure seems to work for everyone here.
this is my ground on the passenger floor of my F150 using 12 Guage.... I ground all the paint off the floor.... I have the floor, ..... then a star washer then the ring terminal then a flat washer then the 5/16 inch bolt head..... under the truck I have another star washer and a lock nut.
one of the grounds goes to my CB Case and to the negative for the CB... and the other wire goes to my kenwood klf-2 dc line noise filter rf suppressor under the passenger seat Kenwood Electronic noise filter
slowmover
Fort Worth
Not all. I usually default to BATT on big truck unless xtra-long home run.
On my pickup I follow DODGE guideline of attaching at fender where BATT NEG is also attached.
Important to test for negative ground anywhere else. Autos are glued together today. Need to be sure.
A common ground set for convenience and to service a 12V Distribution Panel for interior-side given more than one device is another route.
Hdc30474
Yes, cars are glued together these days. Many body parts are put together with seam sealer.
Recent years I have not been able to depend on grounds near the radio. Either the voltage is low or a noise problem. Also as a vehicle ages, even the metal to metal parts can get corrosion between them.
The Dodge recommendation seems to imply you are connecting to the battery at the first ground point after the charging/current sensor which is connected to the battery negative post.
slowmover
Fort Worth
At Fender-well bolt also serves BATT Neg.
Per their guidelines.
slowmover
Fort Worth
Post in thread 'President Washington. No Modulation.'
More goodness.
“. . Not far off I'll have a copilot who can navigate my radio settings. A bit young to be reliable in that department.
He has definitely mastered the PTT though, and he's got the lingo down pat.”
1st Sgnt Dad has readied first ruck for PFC Junior
