BCD325P2/BCD996P2: New To Trunking - control channels
CrazyRach82
Hi,
Previously I have had a GRE PSR-282 and then moved to a Baofeng DM1701 to dip my toe into picking up digital channels.
Recently I have purchased a BCD325P2, and I must say I have found it very daunting, but am getting there slowly. I have no setup anything trunked yet.
I have set up a conventional system, with all the channels I had on my baofeng. I have entered the colour codes, and one thing I have noticed is that during a scan, on 3 of the channels it gets stuck scanning each one and won't move until I make it. 2 of the channels are Capacity + and the other is Hytera.
Does this mean these channels are constantly transmitting and are a control channel which is part of a trunk? There is very rarely any audio comes from these channels, it just gets stuck on the scan.
If these are control channels, then I thought it would be a good place to dip my toe into setting up a trunk. I'm just struggling to know what frequencies to enters and LCN's etc. As I am in the UK, I cannot set up with Radio Reference, so am having to do it all manually.
Any help appreciated,
Rach
dkcorlfla
Orlando
If you are comfortable with computers it would be good to consider setting up a SDR. One of the RTL-SDR v3 or v4 would be enough to get started in SDR. The free version of DSDplus would be enough to ID most of the digital stuff.
The SDR++ program is open source and has a nice waterfall display that will let you see the big picture.
System types, frequencies, and TG ids can be pulled from the logs and be used to help program the scanner.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Hi,I have set up a conventional system, with all the channels I had on my baofeng. I have entered the colour codes, and one thing I have noticed is that during a scan, on 3 of the channels it gets stuck scanning each one and won't move until I make it. 2 of the channels are Capacity + and the other is Hytera.
Welcome to the RR forums. You'll need the DMR upgrade to pick up anything DMR/CAP+/Hytera. Assuming traffic carried on said channels is NOT encrypted then you should have no issues picking up traffic after the DMR/MotoTRBO upgrade is installed. Not sure how much it is in the UK but in the US it's $60 if purchase direct from Uniden
CrazyRach82
Hi, I have the DMR upgrade, there is sound on these channels, it’s just very rare. I’m just wondering why they get stuck on the scan when there’s no sound.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Are they documented in the RRDB? Do you have the presumed CAP+ system programmed as MotoTRBO trunked with correct LCNs and color code(s) set? Perhaps traffic is fully encrypted? If you programmed a CAP+ system conventionally then it will get hung up on a scan with each burst of the rest channel so you need to program as MotoTRBO trunked if the channels aren't conventional
tvengr
Well Known Member
Baltimore County, MD
The OP already has a BCD325P2.
A control channel transmits continuously with the data for controlling a trunked system. A trunked system requires at least one site. Each site has control channel capable frequencies. You can have multiple sites in a trunked system. If you are scanning only one site, the scanner will sit on that site and display the control channel frequency until it receives an active talkgroup. As Whiskey3JMC stated, you will need to purchase the DMR upgrade. Squelch for the BCD325P2 is normally set at 2.
tvengr
Well Known Member
It is a lot easier to use software to program a scanner. FreeSCAN, which is free, does not support DMR or NXDN. For your scanner, you will need ARC XT or ProScan. Both have a free trial period to decide which one you like better. I use Butel ARC XT Basic for my BCD325P2 and BCD996P2.
CrazyRach82
I am in the uk, so my information is limited. It appears to be tier 3, I have no access to an lcn. I do have some information on this’s in use. But only one frequency so far.
Hi,
Rach
Here is a great, easy to understand Tik Tok video from @w2lie and Scanner School that might help
  • Like
Reactions: wtp
