TwoToneDetect New TwoToneDetect in the works - Python based
MikeOrlando02
USB Sound Card Recommendation
Can anyone recommend a good USB sound card for adding a second mic-input to my TTD computer to monitor a second frequency? I purchased the one recommended for the Raspberry PI project off eBay for $1, it looked the same as the link shared from Amazon.
It sounded okay on recordings, but TTD would not recognize the tones on the default 2% tolerance. I had to crank it up to 20% and then I was capturing the wrong agency tones. Other issue is that the bulky housing didn't allow for it to plug in because of the housing on the Tough Book so I had to use a USB extension, not sure if that was the cause of the bad tone detection. Did I get a dud, back knock off, or is there another that would be recommended?
https://www.amazon.com/HDE-Channel-...dp/B0027EMHM6?ie=UTF8&*Version*=1&*entries*=0
Thanks.
MikeOrlando02
I use the "line in" input for one and the "mic" input for the second.
I don't have the Toughbook in front of me, but under the cover for audio there are only two ports. A combo microphone/line in and a headphone jack. I do not believe I have any other audio jacks under any of the other port covers.
BigRedBox80
Is there any way to launch TTD minimized? I'm running two instances on Windows 10 along with a full screen web browser application and even though the browser launches last, the TTD window stays on top.
CommJunkie
FN20jf
Mine has a minimize button ...
BigRedBox80
I suppose I should have specified. This is hands free. TTD and the full screen browser application are startup items, I need this to stay behind the browser so auto minimized would be best.
MikeOrlando02
Typically, you could just edit the shortcut properties to start minimized, but it does not seem that TTD follow's that setting. You could use scripting software like AutoHotKey and run:
Run, TwoToneDetect68a.exe, , Min ; Launch TTD minimized.
Probably the simplest thing to do, without having to install more software like AutoHotKey, would be to use a batch file to delay the opening of your browser so that TTD would launch on top and then after a delay the browser would open, on top of TTD.
@Echo Off
:Wait 15 seconds
TIMEOUT /T 15 /nobreak
"C:\Program Files (x86)\Internet Explorer\iexplore.exe" ::Open browser
BigRedBox80
@Echo Off
:Wait 15 seconds
Unfortunately I'm already trying the timeout thing.
I might have to try the AutoHotKey, I wish TTD would honor the minimize on startup property.
MikeOrlando02
If AHK cannot do it programmatically, worst case it can control the curser with a macro and click on the minimize button on TTD.
asmith136
Raspberry PI Question
I got my first PI up and running works great. I just have 2 questions
1. Is the a display showing TTD like there is on the PC version?
2. Can you run more then 1 TTD on a PI?
MikeOrlando02
Thanks.
Just as a follow-up, I purchased this USB sound card adapter off Amazon for $8. It has a similar issue with audio quality using plug-and-play drivers, but as soon as I installed the drivers it came with it was only few HZ off than the actual tone. Actually, is more accurate than the on-board sound card.
AFUNTA 7.1 Surround Sound 12 Channel Sound Adapter Equalizer USB 2.0 Steel Sound 5hv2 Channel External Sound Card Game(black)
https://amzn.com/B00BP2REBK
pei006
redundant issue
I have been using TTD for many years with great results.
I have upgraded from ver 65 to 68 to use the redundant feature.
I am running 2 instances on the same computer, each fed by its own soundcard
The redundant config files are set to local, file_access = local ,
path is set properly for tone tracking file
the primary instance writes to the common tracking log file fine and sends emails appropriately.
the non primary instance records and converts, writes to audio folder and then stops.
from the log file:
done converting to AMR Chtn ENGINE ONE 23:11:20 on 07/09/16
Traceback (most recent call last):
File "<string>", line 961, in alert
NameError: global name 'ftp_server' is not defined
at this point nothing else happens, no email, wav file is not deleted, ...
if another page is received it is processed and all stops again at this point
with the same error
any ideas?
Thanks in advance
aaknitt
from the log file:
with the same error
any ideas?
Thanks in advance
This is a bug that was just found a few days ago. The "local" redundant feature won't work until this bug is fixed. It's an easy fix, I just need to find some time (probably at least a week or two out) to get a new build put together.
Andy
MikeOrlando02
Feature Request: Emails with Many Recipients
Our MABAS group is large as it is a County-wide list, we are currently around 135 recipients. Almost all email providers limit the number of recipients per message to 100 so our MABAS emails get rejected. My feature request would be to have a config option for the max number of recipients per email. Anything above that would get split into a second message. So my 135 recipient message would go out as 100 recipients in the first email and 35 in the second.
Understandably, we may have a larger list than many so I could see this may not be a very popular need.
-Mike
MikeOrlando02
-Mike
Possibly a better suggestion with more utility would be to create a MABAS/group page setup where in the group you could choose when agency/tone sets belonged to it. In this way you would not have to manage a separate MABAS contact list and instead it would just point back to the individual contact lists for each agency/tone set. When the emails went out it could be a separate email for each agency in the group, which would certainly solve my large single email issue as well.
DC31
Massachusetts
-Mike
Mike,
I have one tone set that is for all personnel in the county (we don't use a MABAS system). That tone set contains 423 email/text addresses. It rarely gets used but last week they sent it out. 420 of them got delivered, 3 bounced back as undeliverable.
My emails go out through a bluehost mail server and through an SMTP forwarding service serversmtp.com
Jim
pei006
Andy
Thank You
I will watch for the new bulld
ryolsen8
BEE07
Copy and Paste
Andy,
For a few of the Co. systems I manage, I keep a master Google Drive copy. What I tried to do today was enter all of my new information into the tones file, and then copy and paste it into the tones notepad file on the computer. For whatever reason, (the picture I've included) these goofy symbols came up. I then had to go back in, and manually remove the "" and re-do it...
Any help or suggestions?
Thank you.
