TwoToneDetect New TwoToneDetect in the works - Python based
fredva
Virginia/West Virginia
I'm using version 6.3 of the software. It was working fine up til about 1 1/2 weeks ago. Then the emails and text messages stopped being sent out. I ran the debug version. After starting the debug version, I believe it sent out one alert, then stopped sending the messages as well. On the failed attempts, the log showed an error:
Traceback (most recent call last):
File "<string>", line 453, in mail
File "C:\Users\Deer Creek Fire Dept\Google Drive\Python\build\pyi.win32\TwoToneDetect63_debug\outPYZ1.pyz/smtplib", line 242, in __init__
gaierror: [Errno 11001] getaddrinfo failed
Email not sent on attempt 1trying again in five seconds
I've been using an aol account with port 587 as the sender. I tried switching to a gmail account but that smtp connection was blocked. As a result of the block, I was offered the opportunity by Google to let unsafe apps send out messages using the gmail account, but so far, I haven't gone that route.
Any ideas on how to overcome this problem? Would upgrading to a newer version of TwoToneDetect resolve the issue?
aaknitt
The "getaddrinfo failed" error indicates that TTD wasn't able to resolve your email server address to an IP address, which is a DNS issue. Did AOL change their email server name? Also, this can sometimes be a temporary problem when a server IP address changes that will eventually resolve itself.
Andy
fredva
Andy
Andy, thank you for that info. I did some more logging though and found that the most consistent error message was connection unexpectedly closed. Perhaps AOL has done something that rejects emailing from what Google is calling less secure apps. What I decided to do for now is to set up a new gmail account, adjust the account settings to theoretically allow TTD to send email using that account, and entered the gmail account info into TTD. Now I'll wait and see if email actually gets sent.
jhsands
Texarkana, Arkansas
Google made me turn on less secure apps for Outlook 2013 and Thunderbird 52. Those were different accounts.
Sent from my S7 using Tapatalk.
fredva
Thanks for the input on my issue. So far the new gmail account I set up with the less secure apps setting is working.
mattnelson26
Hopkins, Minnesota
Help with TTD Monitor Script
I created the attached batch file script to monitor the TTD application running on a Windows PC. I added the batch file to Windows Scheduler to run hourly to monitor the application.
This script will check to see if TTD is running and if it is checks that it is not responding. If the TTD application is not running or unresponsive it attempts to start TTD. If the script is unable to load TTD it restarts the computer, presuming that you have TTD set to start when Windows loads.
I hope to build on this so if you have an FTP server the script can upload a log file showing if TTD was running on last check or not. That will be phase II of the project.
Just change the file type to .bat and place it in the same folder as TTD. Make sure appName is set to the exact name of the TTD EXE version you are running.
Hope this helps someone
is there anyone that could help me set this up i am running multiple ttd on the computer.
thanks,
matt
wfrancis16
Hudson, MA
Format for PushBullet
Does anyone know how to correctly reference the pushbullet channel is the Toneseditor GUI?
For example, I created a channel that is named "Sudbury Box Tone" with a tag of "sudburyboxtone".
After a tone is received that log says that it cannot find the channel. I have already created the access token and entered that into the GUI.
Any help would be appreciated.
DC31
Massachusetts
Can you post the log showing the error?
wfrancis16
Hudson, MA
pushbullet
I removed the "#" . Still not sent. The most recent log is attached.
  • log_2018-04-12_09_59_55_081000.txt
slingshot202
New Jersey
Has anyone ever figured out how to sent an alert to Google voice? For the first time I saw a system that allowed messages to GV, but I still have no idea if there is an email address associated with it, other than the long and lengthy email strings i Have seen when googling the subject.
Figured this might be a good place to ask. Thanks.
DC31
Massachusetts
Okay, but you have a different error message now. This one about not being able to find the audio file usually is a result of ffmpeg not being properly installed.
Also did you restart TTD before testing? You need to restart it to reload your changes.
DC31
Massachusetts
CJ,
Here is one that apparently works for me. Of around 500 subscribers, I only have one GV I believe.
"Name"<12345678890@msg.fi.google.com>
Try it and report back if it works or not.
wfrancis16
Hudson, MA
pushbullet and ffmpeg
I have tried installing ffmpeg and it does not seem to be as straight forward as I thought it would be. I downloaded the latest version static zip file. I then found the .exe file under the bin folder. Where do I place the application? Do I just copy it to the audio folder in the two tone directory?
DC31
Massachusetts
Not in the audio folder. It goes in the TTD folder or whatever you have named your folder that contains the TwoToneDetect program file.
There are specific instructions regarding ffmpeg on Andy&#8217;s web page twotonedetect.net.
jhsands
Texarkana, Arkansas
CJ,
That only works if they are subscribed to the Project Fi service. Good catch, tho.
wfrancis16
Hudson, MA
There are specific instructions regarding ffmpeg on Andy’s web page twotonedetect.net.
FFmpeg is now in the correct directory. It starts up when a tone is received. The error looks different in the log now. The most recent one is attached.
  • log_2018-04-13_13_47_05_225000.txt
