TwoToneDetect New TwoToneDetect in the works - Python based
aaknitt
Code:
upload_file_prefix =
Is there a variable substitution for this? I cannot find it in the PDF. My primary and backup config files have different URLs, but it seems to be a limitation when sharing the tones.cfg file.
Sorry I'm not quite following what you're wanting to accomplish, can you provide more detail? The short answer is no, there isn't any variable substitution for that field.
scannerowner
NW Missouri
Can anyone help? The below is from my log. Any reason why it's not recording and why it's stopping decoding tones?
jhsands
Texarkana, Arkansas
my primary server uploads to fdpage.com and the backup server uploads to s.fdpage.com , so I cannot use the remote config file option because of the separate URLs.
jhsands
Texarkana, Arkansas
Hi all,
Andy all my email-to-texts are being rejected by all 4 major carriers. It started January 6. They are sent back with the following error: ERROR CODE :552 - 5.2.0 Message contains bare LF and is violating 822.bis section 2.3. I've tried sending using zohomail and outlook. I called Zoho and they said it is being rejected by the carrier. I am using version 73m from IAR. Any ideas? Thank you.
are you using a custom domain name or zohomail.com ?
aaknitt
Sorry, I'm still struggling to understand.
The server for FTP upload is specified in the config.cfg file, which isn't retrieved from a remote location. So you should be able to set up each instance to upload to a different location if you want. Or are you using the post_email_command functionality to do your upload instead of the built in SFTP functionality? In that case, perhaps have the script that you're using for upload reference a different server for each instance?
jhsands
Texarkana, Arkansas
Upgraded to 74f and I keep getting this error on 2/3 running instances.
pysftp.exceptions.HostKeysException: No Host Keys Found
After unzipping, put the attached in the logfiles folder. It will automatically add your key.
  • known_hosts.zip
scannerowner
NW Missouri
I was having everything work just fine, and now I'm getting the below error. Any fixes? Everything looks the same as usual...
smtplib.SMTPAuthenticationError: (535, b'5.7.3 Authentication unsuccessful [SN6PR2101CA0011.namprd21.prod.outlook.com 2024-01-26T01:40:32.502Z 08DC1BBC7401878F]')
Email not sent via smtp-mail.outlook.com on port 587 using STARTTLS on attempt 1 trying again in five seconds for
Side note, this appears to be working again. Strange. I didn't change anything.
DC31
Massachusetts
That error indicates that ttd could not log in to your email provider. Probably a username/password authentication problem.
slingshot202
New Jersey
Little Help - I sent to a friend as well, but just seeing if anyone has anything. I have TwoTone on PC up and running on a PC at home, trying to get it working at my FD with Pushover. When an alert goes out I am getting the following error:
Traceback (most recent call last):
File "TwoToneDetect73f.py", line 1187, in uploadFTP
File "ftplib.py", line 117, in __init__
ConnectionResetError: [WinError 10054] An existing connection was forcibly closed by the remote host
I'm certain the pwd is correct.
DC31
Massachusetts
Check with your remote host. They may only allow secure ftp connections (sftp) and not plain ftp.
jhsands
Texarkana, Arkansas
gO TO THE COMMAND PROMPT AND USE FTP TO CONNECT AND SEE WHAT MESSAGE YOU GET. - Sorry about the caps.
slingshot202
New Jersey
When I attempted that I got a blank screen. According to what I read that meant it connected, but the moment I hit enter or anything I go back to the PC prompt.
Now when I just did this same from my personal PC I got an entire prompt, so perhaps the port is not available. Guess have to get the chief talk to the IT guy. LOL - bet that goes well.
jhsands
Texarkana, Arkansas
install cloudflare VPN. It's free, reliable, and trusted.
KB4RU
Why is the IaR members site downloading version 73m while the free link lets you download 74f?
I tried running 74f, but the mp3 recordings are recording at half speed so it’s drawn out, low pitch and hard to understand. I just switched it over to 73m to see if that makes any difference, but v68 will record perfectly fine. I can’t use v68 anymore because it won’t send the emails. Any thoughts on how to fix the playback speed issue?
jhsands
Texarkana, Arkansas
Have not had any issues with 74f and running it on four computers.
KB4RU
What are your computers running?
The computer I am running is a Windows 7 Pro 32bit OS. Are all of your systems running 64bit OS? I am wondering if it may be because of the age of the computer and running a 32bit OS. I have tried everything I can think of, and cannot get the audio fixed. If I run TwoToneDetect 68, the audio files are perfect, but won't send the emails.
KB4RU
I managed to use Wayback machine to find v70. Changed everything over to that version of TwoToneDetect and everything is working appropriately again. I have emails and the audio is clear. I’ll just run v70 as long as I can.
