TwoToneDetect New TwoToneDetect in the works - Python based
scannerowner
NW Missouri
SMTP side not authenticating. Tried putting password in again, no luck. It was working smoothly until a few days ago. Going from Microsoft Hotmail to Gmail.
kc2kvy
I'm trying to run 74h on Ubuntu 24.04.1 LTS, and have tried several other distros as well - I keep running into this problem that I can't resolve.
Code:
TARTING IMPORTS
paramiko/transport.py:220: CryptographyDeprecationWarning: Blowfish has been deprecated and will be removed in a future release
DONE IMPORTING
Version: TwoToneDetect74h
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.32' not found (required by /lib/x86_64-linux-gnu/libavfilter.so.9)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libavfilter.so.9)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.32' not found (required by /lib/x86_64-linux-gnu/librubberband.so.2)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/librubberband.so.2)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.32' not found (required by /lib/x86_64-linux-gnu/libplacebo.so.338)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libplacebo.so.338)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libzmq.so.5)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /lib/x86_64-linux-gnu/libzmq.so.5)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libzimg.so.2)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `CXXABI_1.3.13' not found (required by /lib/x86_64-linux-gnu/libzimg.so.2)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libvpl.so.2)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libgme.so.0)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.32' not found (required by /lib/x86_64-linux-gnu/libopenmpt.so.0)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.31' not found (required by /lib/x86_64-linux-gnu/libopenmpt.so.0)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libopenmpt.so.0)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.32' not found (required by /lib/x86_64-linux-gnu/libchromaprint.so.1)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libchromaprint.so.1)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.32' not found (required by /lib/x86_64-linux-gnu/libsrt-gnutls.so.1.5)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libsrt-gnutls.so.1.5)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libjxl.so.0.7)
ffmpeg: /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by /lib/x86_64-linux-gnu/libjxl_threads.so.0.7)
ffmpeg: /tmp/_MEIZIGb20/libtinfo.so.6: version `NCURSES6_TINFO_6.2.20211010' not found (required by /lib/x86_64-linux-gnu/libncursesw.so.6)
ffmpeg: /tmp/_MEIZIGb20/libgcc_s.so.1: version `GCC_12.0.0' not found (required by /lib/x86_64-linux-gnu/libhwy.so.1)
FFMPEG NOT FOUND
ALSA lib dlmisc.c:170:(snd_dlsym_verify) unable to verify version for symbol snd_func_private_integer
ALSA lib conf.c:4720:(_snd_config_evaluate) symbol snd_func_private_integer is not defined inside (null)
ALSA lib conf.c:5220:(snd_config_expand) Evaluate error: No such device or address
ALSA lib conf.c:3858:(snd_config_hook_load) Unable to expand filenames in the pre-load section
ALSA lib conf.c:3736:(snd_config_hooks_call) function snd_config_hook_load_for_all_cards returned error: No such device or address
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib dlmisc.c:283:(snd_dlobj_cache_get0) Cannot open shared library /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_rate_lavrate.so ((null): /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libvpl.so.2))
ALSA lib pcm_rate.c:1450:(snd_pcm_rate_open) Cannot find rate converter
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib dlmisc.c:283:(snd_dlobj_cache_get0) Cannot open shared library /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_pcm_a52.so ((null): /tmp/_MEIZIGb20/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /lib/x86_64-linux-gnu/libjxl.so.0.7))
ALSA lib dlmisc.c:283:(snd_dlobj_cache_get0) Cannot open shared library /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_pcm_usb_stream.so ((null): /usr/lib/x86_64-linux-gnu/alsa-lib/libasound_module_pcm_usb_stream.so: undefined symbol: snd_config_get_card, version ALSA_0.9)
ALSA lib pcm_direct.c:2023:(snd1_pcm_direct_parse_open_conf) Unknown field tstamp_type
pulse selected as audio input device
pulse selected as audio output device
Successfully retrieved local tone info at 07:55:02 on 10/15/24
tone config has changed & will now be updated
no alerts active - updating tone config at 1728993302.3564684
<function backend.<locals>.appindicator at 0x7969ed052040>
Traceback (most recent call last):
  File "pystray/_appindicator.py", line 23, in <module>
  File "gi/__init__.py", line 129, in require_version
ValueError: Namespace AppIndicator3 not available
During handling of the above exception, another exception occurred:
  File "TwoToneDetect74h.py", line 2445, in <module>
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "PyInstaller/loader/pyimod02_importers.py", line 499, in exec_module
  File "pystray/__init__.py", line 66, in <module>
  File "pystray/__init__.py", line 57, in backend
  File "pystray/__init__.py", line 28, in appindicator
  File "pystray/_appindicator.py", line 26, in <module>
ValueError: Namespace AyatanaAppIndicator3 not available
[7801] Failed to execute script 'TwoToneDetect74h' due to unhandled exception!
  File "<string>", line 1, in <module>
AttributeError: 'Logger' object has no attribute 'flush'
Exception ignored in: <__main__.Logger object at 0x7969edae9d00>
NotATechGuy
NotAMember
Code:
TARTING IMPORTS
DONE IMPORTING
FFMPEG NOT FOUND
"FFMPEG NOT FOUND" ;
It's missing the FFMPEG dependency. Have you tried installing FFMPEG?
kc2kvy
I do have ffmpeg installed on my system. I've tried reinstalling it multiple times.
EDIT: trying this solution now, will update later.
NotATechGuy
NotAMember
Yes, you can not use the apt repository for FFMPEG. You must build it from source with the required libraries and configure it with the proper flags. The post you linked to should work however I have not tested 74h so YMMV.
kc2kvy
Unfortunately it did not work.
EDIT: OK, I did:
Code:
sudo apt install gir1.2-appindicator3-0.1
and it starts up now! I'm still getting FFMPEG NOT FOUND though...
EDIT 2: Not working for me, unfortunately. I miss the days when I ran TTD on a Raspberry pi and it worked flawlessly!
kc2kvy
I've installed ffmpeg about six different ways and still nothing. I wish this was distributed as a flatpak!
DC31
Massachusetts
EDIT: OK, I did:
Code:
So why not go back to the raspberry pi? Just don’t use a pi5 or the Bookworm OS.
kc2kvy
I don’t have a functioning pi anymore. I do have a server already spun up, and I figured it wouldn’t be this difficult to get TTD working… I’m not new to Linux or tracking down dependencies, but I just am not sure what TTD needs when I have the things it’s asking for installed.
kc2kvy
I hate this solution, but I've got it running under Wine.
bunangst
Harmony, NJ
I've been through the ffmpeg compiling process before...but I'm curious. Does anyone know what special options are required for TTD that forces the compile from source?
NotATechGuy
NotAMember
TTD checks for FFMPEG by running the command `ffmpeg -version`. It needs support for mp3 and aac to convert audio. There's probably more technical details that the dev or someone else can fill in. Open a terminal and run the command `ffmpeg -version`. If you previously used a package manager like apt you may need to fix your path to point to your compiled by source version.
aaknitt
It's from the old flip-phone days when some phones couldn't play MP3 files but could play AMR files. TTD converts recordings to both formats. Some time ago ffmpeg dropped support for AMR from the standard builds but TTD still needs it for that legacy functionality. TTD will probably drop support for AMR in a future release because nearly everything can support mp3 now. When that happens, standard ffmpeg builds will work again without having to compile.
Andy
bunangst
Harmony, NJ
Andy
Thanks Andy. I've been using TTD a long time and never had to use AMR.
With as cheap as storage and bandwidth is getting these days...maybe we'll just go back to lossless WAV files :ROFLMAO:
dwgelle
Meeker Co.- MN
I've noticed now not getting the text message to Verizon phone. But it is going to Gmail and getting silent via Gmail.
