yit5yoit
I have tried decoding digital signals using dsd+ but i get no sound output even if input and output are set true i have tried using sdrpp sdr sharp with and without plugins three different computters and also didnt find information about this
PDXh0b0
Woodland, WA
Assuming you are using dsdplus101.
Windows Sound manager(recording tab) - make sure your output choice in sdr#/sdr++ is set as default there
Still no audio.. check windows microphone security permissions
yit5yoit
it didnt help but the problem could be that the output device has some random characters but on another pc there was no unknown characters and still didnt workdsd.PNG
CanesFan95
Analog already is interoperable.
FL
There's 2 different sound settings, one from the Control Panel and one in the Windows settings. Check 'em both:
What version of DSD+ are you running and how are you running / starting it? When you say "set true", what does that mean? If you created your own .bat file, show us the command line you're running.
yit5yoit
im just running the .exe file i have not done anything using bat files and im using dsdplus 101
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
The EXE itself is not going to produce sound. You need an imput signal either from FMP/FMP24.exe or from an SDR program + Virtual Cable or from a discriminator tap.
And it's only going to produce sound when you are monitoring a digital frequency / system / site that DSDPlus can decode AND there is voice traffic.
yit5yoit
I didn't understand that very well but I'm using sdrpp and through virtual cable sending it to dsd plus
CanesFan95
FL
You need a command line argument -i, such as -i1 or -i2 to tell DSD+ what the input audio device should be. So you can't just double-click on DSDPlus.exe. Instead, you need to run it from a command terminal or a .bat file with the command argument(s).
Reconrider
Inside the Galaxy
Radio Galaxy
I would suggest reading the txt files in that folder. After that looking up youtube tutorials - that will be the best guidance so you can start and stop as you're going so you can follow along.
PDXh0b0
Woodland, WA
That is p25 p1, you'll need two dongles with dsdplus101 (see trunking.txt)
Sdrtrunk with work with one dongle and track
dsdplus101 running the audio for your video, you will not get voice from p25 control channel
