noise
Gumball928
New to this . . . .what is the "rahr . . .rahr . . .rahr noise ???? What is causing it ?? What can I do to stop it (other than lockout )
Gumball928
SDS200, any channel, any frequency. Occasionally it will lock on a frequency, and all there is "rawr . . .rawr . . . .rawr . . . ." repeating.
Trying to understand what is causing it.
If it's on every frequency, then it's something local to your radio. Try shutting off computer power supplies, USB adapters, cable/DSL modems, etc. If that does not fix it, go to your home's circuit breaker panel and shut off one circuit breaker at a time and see if one of them stops the noise. Then narrow down the culprit from there. If the circuit breaker trick does not help you narrow it down, it may be from a neighbor.
Saint
Fort Erie Ontario Canada
Have you checked out who could be using that frequency in your area that you could pickup, if it's not a frequency that is active in your area then just lock it out.
Saint
kc2asb
NYC Area
Are you near any radio / TV / cellphone towers? Since it is appearing on any frequency / channel, perhaps your scanner is being overloaded by a powerful nearby signal.
mdevoe
mi
Sounds like a dmr frequency that is not fully being decoded. The signal isn't strong enough to deccode correctly.
Gumball928
I am sorry, it is difficult to explain a sound, but thank all for their assistance.
It is not electrical interference, more like a close frequency that is not exact.
kc2asb
NYC Area
If you can make a recording of it, please post it there. Someone will be able to tell you what it is.
u2brent
OAMPT
KRWDPAXKRS1
Another point not covered.. That I could see.
Did you purchase any upgrades?
If not you could be hearing undecoded DMR transmissions.
Trilliumaire
Evergreen, CO
Sounds like some sort of interference. Can you move the SDS200 to some other place and see if it changes? Also, turn off your "close call".
EAFrizzle
Bond. Ward Bond
SE de DFW
You might want to try different settings on the global filter to see if that helps any. Once we can get this narrowed down, someone should be able to suggest the best solution for the problem.
